跳转到主内容
HP Deskjet 1000 J110a Parts Replacement
你所需要的
  1. HP Deskjet 1000 J110a  Parts Replacement, Cover Removal: 步骤 1 中的图像 1,3 HP Deskjet 1000 J110a  Parts Replacement, Cover Removal: 步骤 1 中的图像 2,3 HP Deskjet 1000 J110a  Parts Replacement, Cover Removal: 步骤 1 中的图像 3,3
    • Remove the two 13 mm screws located on the back of the printer using a screwdriver with the T10 torx bit (star-shaped).
  2. HP Deskjet 1000 J110a  Parts Replacement: 步骤 2 中的图像 1,3 HP Deskjet 1000 J110a  Parts Replacement: 步骤 2 中的图像 2,3 HP Deskjet 1000 J110a  Parts Replacement: 步骤 2 中的图像 3,3
    • In the front of the printer, open the tray where the paper comes out and remove the two 13 mm screws located under the top of the printer.
  3. HP Deskjet 1000 J110a  Parts Replacement: 步骤 3 中的图像 1,1
    • With the front of the printer facing you, lift and raise the left side of the panel (like opening a book in reverse) until it disconnects from the clip on the right side of the panel.
结论
2等其他人完成本指南。
Colin Tourjee
于01/29/18注册
632 声望
创作了4篇指南
团队
USF Tampa, Team S5-G3, Passmore Spring 2018 USF Tampa, Team S5-G3, Passmore Spring 2018 的会员
USFT-PASSMORE-S18S5G3
4 名成员
创作了12篇指南
2条评论
Very intuitive, good instructions. Highly recommended.
Krzysztof Białkowski - 回复
Thank you very much for the instructions on removing the cover to the HP 1200 Deskjet. It allowed me to removed a part that fell into the printer and prevented the paper from advancing.
karenliller@comcast.net - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 980
