简介
This guide will take you through the process of replacing the screen on an HP Compaq nc6400 Laptop. You will need the correct replacement screen for your laptop to complete the installation.
你所需要的
Locate the lock labeled two at the bottom right corner below the battery.
Slide and hold the lock to the left.
Remove the four 1.2mm Philips #1 screws attaching the plastic cover to the monitor.
The screws may have a small, black plastic cover that lays flush with the screen. Remove these using a pointed tool such as the spudger or philips head screwdriver by prying them out.
4等其他人完成本指南。
