跳转到主内容
HP Compaq nc6400 Screen Replacement
你所需要的
  1. HP Compaq nc6400 Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off and unplug laptop.
  2. HP Compaq nc6400 Screen Replacement: 步骤 2 中的图像 1,1
    • Locate the battery lock below the battery labeled one.
    • Slide the lock all the way to the left to release the left lock of the battery.
  3. HP Compaq nc6400 Screen Replacement: 步骤 3 中的图像 1,1
    • Locate the lock labeled two at the bottom right corner below the battery.
    • Slide and hold the lock to the left.
  4. HP Compaq nc6400 Screen Replacement: 步骤 4 中的图像 1,1
    • Once both the battery locks are unlocked, slide the battery out to remove.
  5. HP Compaq nc6400 Screen Replacement, Screen: 步骤 5 中的图像 1,1
    • Remove the four 1.2mm Philips #1 screws attaching the plastic cover to the monitor.
    • The screws may have a small, black plastic cover that lays flush with the screen. Remove these using a pointed tool such as the spudger or philips head screwdriver by prying them out.
  6. HP Compaq nc6400 Screen Replacement: 步骤 6 中的图像 1,1
    • Remove the four 1.2 Philips #1 screws attaching the face plate to the body.
  7. HP Compaq nc6400 Screen Replacement: 步骤 7 中的图像 1,3 HP Compaq nc6400 Screen Replacement: 步骤 7 中的图像 2,3 HP Compaq nc6400 Screen Replacement: 步骤 7 中的图像 3,3
    • Pry up the plastic screen cover using a pry tool.
    • Keeping the pry tool under the trim, slide it around the entire screen until the the cover has completely detached from the base.
    • You might need to slide the display clip on the top of the screen in order to fully remove the plastic cover.
  8. HP Compaq nc6400 Screen Replacement: 步骤 8 中的图像 1,2 HP Compaq nc6400 Screen Replacement: 步骤 8 中的图像 2,2
    • Remove the two 1.2 Philips #1 screws holding down the sensor board at the bottom of the monitor.
  9. HP Compaq nc6400 Screen Replacement: 步骤 9 中的图像 1,1
    • Remove the right-most 1.2mm Philips #1 screw on the bottom of the monitor.
  10. HP Compaq nc6400 Screen Replacement: 步骤 10 中的图像 1,2 HP Compaq nc6400 Screen Replacement: 步骤 10 中的图像 2,2
    • Without lifting the bottom of the monitor, gently flip the screen and lay it face down on the keyboard.
  11. HP Compaq nc6400 Screen Replacement: 步骤 11 中的图像 1,2 HP Compaq nc6400 Screen Replacement: 步骤 11 中的图像 2,2
    • Remove the tape holding down the video cable to the monitor.
    • Gently pull out the video cable from the monitor.
  12. HP Compaq nc6400 Screen Replacement: 步骤 12 中的图像 1,2 HP Compaq nc6400 Screen Replacement: 步骤 12 中的图像 2,2
    • Remove the monitor's power cable from the sensor board.
    • This is the cable on the farthest right of the sensor board.
  13. HP Compaq nc6400 Screen Replacement: 步骤 13 中的图像 1,2 HP Compaq nc6400 Screen Replacement: 步骤 13 中的图像 2,2
    • Once all cables attaching the casing to the monitor have been disconnected, remove the entire screen from the computer and lay it on a flat surface.
    • Remove the four 1.2 Philips #1 screws attaching the bezel to the right side of the monitor.
    • Attach bezel to replacement screen.
结论
4等其他人完成本指南。
Luis Vazquez
于09/24/13注册
401 声望
创作了2篇指南
团队
Cal Poly, Team 14-6, Forte Fall 2013 Cal Poly, Team 14-6, Forte Fall 2013 的会员
CPSU-FORTE-F13S14G6
5 名成员
创作了5篇指南
一条评论
Nicely done. Thanks?
Peter Q. - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 23
总计 5,478
