跳转到主内容
HP Compaq nc6400 RAM Replacement
你所需要的
  1. HP Compaq nc6400 RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off and unplug laptop.
  2. HP Compaq nc6400 RAM Replacement: 步骤 2 中的图像 1,1
    • Locate the battery lock below the battery labeled one.
    • Slide the lock all the way to the left to release the left lock of the battery.
  3. HP Compaq nc6400 RAM Replacement: 步骤 3 中的图像 1,1
    • Locate the lock labeled two at the bottom right corner below the battery.
    • Slide and hold the lock to the left.
  4. HP Compaq nc6400 RAM Replacement: 步骤 4 中的图像 1,1
    • Once both the battery locks are unlocked, slide the battery out to remove.
  5. HP Compaq nc6400 RAM Replacement, RAM: 步骤 5 中的图像 1,2 HP Compaq nc6400 RAM Replacement, RAM: 步骤 5 中的图像 2,2
    • Remove the 1.2 Philips #1 screw holding down the RAM cover to the body.
  6. HP Compaq nc6400 RAM Replacement: 步骤 6 中的图像 1,1
    • Once the screw is removed, use a spudger to pry open the case covering the RAM chip.
  7. HP Compaq nc6400 RAM Replacement: 步骤 7 中的图像 1,2 HP Compaq nc6400 RAM Replacement: 步骤 7 中的图像 2,2
    • Use a plastic opening tool to pull back the white clip holding the RAM chip in place.
    • Once the plastic opening tool has disengaged the clip from the RAM chip, keep the plastic opening tool locked into place.
  8. HP Compaq nc6400 RAM Replacement: 步骤 8 中的图像 1,1
    • With a second plastic opening tool,repeat the above process
    • After both plastic opening tools have been locked in place, the RAM chip should pop out about 1/4 of a inch.
  9. HP Compaq nc6400 RAM Replacement: 步骤 9 中的图像 1,2 HP Compaq nc6400 RAM Replacement: 步骤 9 中的图像 2,2
    • The RAM chip is susceptible to static electricity. Before grabbing the RAM chip, make sure you have discharged the electricity from your hands by touching a metal surface other than your computer.
    • Grab the RAM chip with your thumb and index finger
    • Carefully pull the RAM chip out
结论
5等其他人完成本指南。
Luis Vazquez
于09/24/13注册
401 声望
创作了2篇指南
团队
Cal Poly, Team 14-6, Forte Fall 2013 Cal Poly, Team 14-6, Forte Fall 2013 的会员
CPSU-FORTE-F13S14G6
5 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 4,626
