跳转到主内容
HP Compaq nc6400 Optical Drive Replacement
你所需要的
  1. HP Compaq nc6400 Optical Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off and unplug laptop.
  2. HP Compaq nc6400 Optical Drive Replacement: 步骤 2 中的图像 1,1
    • Locate the battery lock below the battery labeled one.
    • Slide the lock all the way to the left to release the left lock of the battery.
  3. HP Compaq nc6400 Optical Drive Replacement: 步骤 3 中的图像 1,1
    • Locate the lock labeled two at the bottom right corner below the battery.
    • Slide and hold the lock to the left.
  4. HP Compaq nc6400 Optical Drive Replacement: 步骤 4 中的图像 1,1
    • Once both the battery locks are unlocked, slide the battery out to remove.
  5. HP Compaq nc6400 Optical Drive Replacement, Optical Drive: 步骤 5 中的图像 1,2 HP Compaq nc6400 Optical Drive Replacement, Optical Drive: 步骤 5 中的图像 2,2
    • Remove the 4 mm P0 Phillips-head screw indicated by the icon of a lock and disk.
  6. HP Compaq nc6400 Optical Drive Replacement: 步骤 6 中的图像 1,2 HP Compaq nc6400 Optical Drive Replacement: 步骤 6 中的图像 2,2
    • Press and release the eject icon to partially eject the optical drive.
    • Use of a spudger may be necessary to pry open the optical drive.
  7. HP Compaq nc6400 Optical Drive Replacement: 步骤 7 中的图像 1,1
    • Grasp the sides and pull the optical drive out.
结论
2等其他人完成本指南。
Chad Williams
于09/30/13注册
252 声望
撰写一个指南
团队
Cal Poly, Team 14-6, Forte Fall 2013 Cal Poly, Team 14-6, Forte Fall 2013 的会员
CPSU-FORTE-F13S14G6
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 4,674
