跳转到主内容
HP Compaq nc6400 Keyboard Replacement
你所需要的
  1. HP Compaq nc6400 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off and unplug laptop.
  2. HP Compaq nc6400 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Locate the battery lock below the battery labeled one.
    • Slide the lock all the way to the left to release the left lock of the battery.
  3. HP Compaq nc6400 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Locate the lock labeled two at the bottom right corner below the battery.
    • Slide and hold the lock to the left.
  4. HP Compaq nc6400 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Once both the battery locks are unlocked, slide the battery out to remove.
  5. HP Compaq nc6400 Keyboard Replacement, Keyboard: 步骤 5 中的图像 1,1
    • Locate and remove the 3 screws holding the keyboard in place from underneath the laptop.
  6. HP Compaq nc6400 Keyboard Replacement: 步骤 6 中的图像 1,3 HP Compaq nc6400 Keyboard Replacement: 步骤 6 中的图像 2,3 HP Compaq nc6400 Keyboard Replacement: 步骤 6 中的图像 3,3
    • Locate and remove the four retaining clips from the edge of the keyboard. To remove pry up gently on the outside edge of the plastic clip. Once the clip pops up pull it straight out.
  7. HP Compaq nc6400 Keyboard Replacement: 步骤 7 中的图像 1,2 HP Compaq nc6400 Keyboard Replacement: 步骤 7 中的图像 2,2
    • At this point the back of the keyboard should come up a bit. You may need to use a thin tool to pull it up, but in my case I only needed my hands. Once you have the back of the keyboard propped up as shown pull the keyboard gently towards the screen to remove. Be careful not to pull completely out because there are still connectors attached to it.
  8. HP Compaq nc6400 Keyboard Replacement: 步骤 8 中的图像 1,2 HP Compaq nc6400 Keyboard Replacement: 步骤 8 中的图像 2,2
    在这个步骤中使用的工具:
    • Now with tweezers or a gentle prying apparatus gently pull the lock on the retaining clip up to release each ribbon cable. It is important to only pull up on the lock and not the entire clip.
  9. HP Compaq nc6400 Keyboard Replacement: 步骤 9 中的图像 1,2 HP Compaq nc6400 Keyboard Replacement: 步骤 9 中的图像 2,2
    • At this point the keyboard should be completely detached and ready to be removed. Be sure to take your time installing the ribbon cables as these can be troublesome if not installed properly
结论
3等其他人完成本指南。
Andrew Frost
于03/12/14注册
197 声望
撰写一个指南
团队
UMass Dartmouth, Team 5-3, Cichon Spring 2014 UMass Dartmouth, Team 5-3, Cichon Spring 2014 的会员
UMASSD-CICHON-S14S5G3
4 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 2,747
