跳转到主内容
HP Compaq dx2000MT RAM Replacement
你所需要的
  1. HP Compaq dx2000MT RAM Replacement, Removing the HP Compaq dx2000MT Case Doors: 步骤 1 中的图像 1,1
    • Turn off your computer and remove the power cable by pulling it straight out of its socket.
  2. HP Compaq dx2000MT RAM Replacement: 步骤 2 中的图像 1,2 HP Compaq dx2000MT RAM Replacement: 步骤 2 中的图像 2,2
    • Remove the two Phillips #2 screws that secure the case door to the device.
  3. HP Compaq dx2000MT RAM Replacement: 步骤 3 中的图像 1,3 HP Compaq dx2000MT RAM Replacement: 步骤 3 中的图像 2,3 HP Compaq dx2000MT RAM Replacement: 步骤 3 中的图像 3,3
    • Remove the side case door by pushing towards the rear of the device with your hand.
    • This may take considerable force so keep pushing!
    • Once you slide the door back, remove it by pulling it outwards from the device.
  4. HP Compaq dx2000MT RAM Replacement: 步骤 4 中的图像 1,3 HP Compaq dx2000MT RAM Replacement: 步骤 4 中的图像 2,3 HP Compaq dx2000MT RAM Replacement: 步骤 4 中的图像 3,3
    • Once again, this may take considerable force.
  5. HP Compaq dx2000MT RAM Replacement, Disassembling HP Compaq dx2000MT Hard Drive: 步骤 5 中的图像 1,3 HP Compaq dx2000MT RAM Replacement, Disassembling HP Compaq dx2000MT Hard Drive: 步骤 5 中的图像 2,3 HP Compaq dx2000MT RAM Replacement, Disassembling HP Compaq dx2000MT Hard Drive: 步骤 5 中的图像 3,3
    • Remove the IDE data and power cables from the hard drive.
  6. HP Compaq dx2000MT RAM Replacement: 步骤 6 中的图像 1,3 HP Compaq dx2000MT RAM Replacement: 步骤 6 中的图像 2,3 HP Compaq dx2000MT RAM Replacement: 步骤 6 中的图像 3,3
    • Remove the front bezel by pulling upwards and out from below the lowest air vent.
  7. HP Compaq dx2000MT RAM Replacement: 步骤 7 中的图像 1,3 HP Compaq dx2000MT RAM Replacement: 步骤 7 中的图像 2,3 HP Compaq dx2000MT RAM Replacement: 步骤 7 中的图像 3,3
    • Remove the external drive faceplate by removing the two Torx T15 screws.
  8. HP Compaq dx2000MT RAM Replacement: 步骤 8 中的图像 1,2 HP Compaq dx2000MT RAM Replacement: 步骤 8 中的图像 2,2
    • Remove the following screws:
    • Front Torx T15.
    • Torx T15 mounting the hard drive cage to the optical drive bay.
  9. HP Compaq dx2000MT RAM Replacement: 步骤 9 中的图像 1,3 HP Compaq dx2000MT RAM Replacement: 步骤 9 中的图像 2,3 HP Compaq dx2000MT RAM Replacement: 步骤 9 中的图像 3,3
    • Fully remove the hard drive cage by sliding it towards the back of the device and pulling down.
  10. HP Compaq dx2000MT RAM Replacement: 步骤 10 中的图像 1,3 HP Compaq dx2000MT RAM Replacement: 步骤 10 中的图像 2,3 HP Compaq dx2000MT RAM Replacement: 步骤 10 中的图像 3,3
    • Remove the two Torx T15 screws holding this side of the hard drive in place.
  11. HP Compaq dx2000MT RAM Replacement: 步骤 11 中的图像 1,3 HP Compaq dx2000MT RAM Replacement: 步骤 11 中的图像 2,3 HP Compaq dx2000MT RAM Replacement: 步骤 11 中的图像 3,3
    • Proceed to the other side of the hard drive cage.
  12. HP Compaq dx2000MT RAM Replacement: 步骤 12 中的图像 1,2 HP Compaq dx2000MT RAM Replacement: 步骤 12 中的图像 2,2
    • Remove the hard drive from the hard drive cage by pulling it outward from the cage.
  13. HP Compaq dx2000MT RAM Replacement, RAM: 步骤 13 中的图像 1,2 HP Compaq dx2000MT RAM Replacement, RAM: 步骤 13 中的图像 2,2
    • Release the lower portion of the RAM by pushing down on the bottom tab.
  14. HP Compaq dx2000MT RAM Replacement: 步骤 14 中的图像 1,2 HP Compaq dx2000MT RAM Replacement: 步骤 14 中的图像 2,2
    • Release the upper portion of the RAM by pushing down on the upper tab.
  15. HP Compaq dx2000MT RAM Replacement: 步骤 15 中的图像 1,3 HP Compaq dx2000MT RAM Replacement: 步骤 15 中的图像 2,3 HP Compaq dx2000MT RAM Replacement: 步骤 15 中的图像 3,3
    • Remove the RAM by pulling it out towards the side of the device
    • Be careful about touching the top (right) and bottom (left)sides of the RAM! The static electricity in your fingers could short it. If you can, only touch the top and bottom of the RAM.
    • If replacing RAM, make sure it is the right type, speed, and size for your computer. Otherwise the RAM may not fit or your computer may not start up.
结论
另外一个人完成了本指南。
Logan Pace
于10/12/11注册
2,312 声望
创作了9篇指南
团队
Cal Poly, Team 17-16, Regan Fall 2011 Cal Poly, Team 17-16, Regan Fall 2011 的会员
CPSU-REGAN-F11S17G16
4 名成员
创作了17篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 28
总计 4,895
