跳转到主内容
HP Compaq Presario cq62-214nr RAM Replacement
你所需要的
  1. HP Compaq Presario cq62-214nr RAM Replacement, Battery: 步骤 1 中的图像 1,2 HP Compaq Presario cq62-214nr RAM Replacement, Battery: 步骤 1 中的图像 2,2
    • It is advised to work on this device only when it is OFF, to avoid electrocution risks. Please make sure your laptop is powered off.
    • On the underside of the battery, there is lock that keeps the battery in place. Using your finger, slide the battery lock to unlock the battery. When you have unlocked it, just lift the battery to remove it.
    • We do not have a battery on our device to show how to take it off.
  2. HP Compaq Presario cq62-214nr RAM Replacement, RAM: 步骤 2 中的图像 1,2 HP Compaq Presario cq62-214nr RAM Replacement, RAM: 步骤 2 中的图像 2,2
    • Remove the three M2.5x5 mm Phillips screws securing the memory case.
  3. HP Compaq Presario cq62-214nr RAM Replacement: 步骤 3 中的图像 1,2 HP Compaq Presario cq62-214nr RAM Replacement: 步骤 3 中的图像 2,2
    • Using a plastic opening tool, insert it alongside any openings on the case. Lift and slide the tool to remove the case.
  4. HP Compaq Presario cq62-214nr RAM Replacement: 步骤 4 中的图像 1,2 HP Compaq Presario cq62-214nr RAM Replacement: 步骤 4 中的图像 2,2
    • Remove the top RAM chip by lifting up and pulling it towards the left.
    • Once the top RAM chip is removed, remove the one underneath using the same method.
结论
Roth Marcelin
于10/06/16注册
726 声望
创作了6篇指南
团队
USF Tampa, Team 2-6, Sullivan Fall 2016 USF Tampa, Team 2-6, Sullivan Fall 2016 的会员
USFT-SULLIVAN-F16S2G6
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 11
总计 585
