跳转到主内容
HP Compaq Presario cq62-214nr Motherboard Replacement
你所需要的
  1. HP Compaq Presario cq62-214nr Motherboard Replacement, Keyboard: 步骤 1 中的图像 1,2 HP Compaq Presario cq62-214nr Motherboard Replacement, Keyboard: 步骤 1 中的图像 2,2
    • With all the screws removed from the previous guides. Remove the final eight M2.5X5 mm Philips screws on the back of the laptop
  2. HP Compaq Presario cq62-214nr Motherboard Replacement: 步骤 2 中的图像 1,2 HP Compaq Presario cq62-214nr Motherboard Replacement: 步骤 2 中的图像 2,2
    • In the battery housing, there are three screws that hold the keyboard on. These screws are located on the side near the front.
    • In the center of the bottom of the computer between the RAM and the wifi antenna is a 4th keyboard screw that also needs to be removed.
  3. HP Compaq Presario cq62-214nr Motherboard Replacement: 步骤 3 中的图像 1,3 HP Compaq Presario cq62-214nr Motherboard Replacement: 步骤 3 中的图像 2,3 HP Compaq Presario cq62-214nr Motherboard Replacement: 步骤 3 中的图像 3,3
    • Open up the front of the laptop. Use a plastic opening tool to carefully pry open the keyboard from the edges.
  4. HP Compaq Presario cq62-214nr Motherboard Replacement: 步骤 4 中的图像 1,1
    • Remove the keyboard by pulling on it with your hands.
    • There is a ribbon cable that is still connected on the back of the keyboard. Do not pull off the ribbon cable when pulling up the keyboard.
  5. HP Compaq Presario cq62-214nr Motherboard Replacement: 步骤 5 中的图像 1,3 HP Compaq Presario cq62-214nr Motherboard Replacement: 步骤 5 中的图像 2,3 HP Compaq Presario cq62-214nr Motherboard Replacement: 步骤 5 中的图像 3,3
    • Locate the keyboard cable/wire that attaches the keyboard to the laptop .
    • Locate the latch of the wire connector
    • Unlatch the wire connector and gently pull out the wire with your hands
  6. HP Compaq Presario cq62-214nr Motherboard Replacement, Motherboard: 步骤 6 中的图像 1,1
    • Remove the four M2.5x5 mm Phillips screws from the exposed keyboard cover.
  7. HP Compaq Presario cq62-214nr Motherboard Replacement: 步骤 7 中的图像 1,3 HP Compaq Presario cq62-214nr Motherboard Replacement: 步骤 7 中的图像 2,3 HP Compaq Presario cq62-214nr Motherboard Replacement: 步骤 7 中的图像 3,3
    • Locate the three tab holding down the cover of the Motherboard.
    • Lift the tabs with using either a plastic opening tool or your fingers.
  8. HP Compaq Presario cq62-214nr Motherboard Replacement: 步骤 8 中的图像 1,2 HP Compaq Presario cq62-214nr Motherboard Replacement: 步骤 8 中的图像 2,2
    • Using a plastic opening tool to lift the sides of the cover.
  9. HP Compaq Presario cq62-214nr Motherboard Replacement: 步骤 9 中的图像 1,3 HP Compaq Presario cq62-214nr Motherboard Replacement: 步骤 9 中的图像 2,3 HP Compaq Presario cq62-214nr Motherboard Replacement: 步骤 9 中的图像 3,3
    • Use your hands to gently lift the cover off.
  10. HP Compaq Presario cq62-214nr Motherboard Replacement: 步骤 10 中的图像 1,3 HP Compaq Presario cq62-214nr Motherboard Replacement: 步骤 10 中的图像 2,3 HP Compaq Presario cq62-214nr Motherboard Replacement: 步骤 10 中的图像 3,3
    • Locate the four cables securing the Motherboard.
    • Gently pull cables to unsecure them.
  11. HP Compaq Presario cq62-214nr Motherboard Replacement: 步骤 11 中的图像 1,3 HP Compaq Presario cq62-214nr Motherboard Replacement: 步骤 11 中的图像 2,3 HP Compaq Presario cq62-214nr Motherboard Replacement: 步骤 11 中的图像 3,3
    • Remove the three M2.25x5 mm Phillips screws.
  12. HP Compaq Presario cq62-214nr Motherboard Replacement: 步骤 12 中的图像 1,3 HP Compaq Presario cq62-214nr Motherboard Replacement: 步骤 12 中的图像 2,3 HP Compaq Presario cq62-214nr Motherboard Replacement: 步骤 12 中的图像 3,3
    • Unlatch the final cable and gently remove the Motherboard.
结论
3等其他人完成本指南。
Roth Marcelin
于10/06/16注册
726 声望
创作了6篇指南
团队
USF Tampa, Team 2-6, Sullivan Fall 2016 USF Tampa, Team 2-6, Sullivan Fall 2016 的会员
USFT-SULLIVAN-F16S2G6
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 20
总计 1,072
