跳转到主内容
HP Compaq Presario cq62-214nr Keyboard Replacement
你所需要的
  1. HP Compaq Presario cq62-214nr Keyboard Replacement, Battery: 步骤 1 中的图像 1,2 HP Compaq Presario cq62-214nr Keyboard Replacement, Battery: 步骤 1 中的图像 2,2
    • It is advised to work on this device only when it is OFF, to avoid electrocution risks. Please make sure your laptop is powered off.
    • On the underside of the battery, there is lock that keeps the battery in place. Using your finger, slide the battery lock to unlock the battery. When you have unlocked it, just lift the battery to remove it.
    • We do not have a battery on our device to show how to take it off.
  2. HP Compaq Presario cq62-214nr Keyboard Replacement, Hard Drive: 步骤 2 中的图像 1,2 HP Compaq Presario cq62-214nr Keyboard Replacement, Hard Drive: 步骤 2 中的图像 2,2
    • Loosen the two M2.5x3 mm Phillips screws securing the hard drive cover.
  3. HP Compaq Presario cq62-214nr Keyboard Replacement: 步骤 3 中的图像 1,1
    • On the same side as the two screws, there should now be an opening to lift off the cover. Using a plastic opening tool, sightly lift the case up to remove it.
  4. HP Compaq Presario cq62-214nr Keyboard Replacement: 步骤 4 中的图像 1,2 HP Compaq Presario cq62-214nr Keyboard Replacement: 步骤 4 中的图像 2,2
    • Remove the three M2.5x5 mm Phillips screws securing the hard drive assembly.
  5. HP Compaq Presario cq62-214nr Keyboard Replacement: 步骤 5 中的图像 1,1
    • Our laptop did not have a hard drive, so it is not included in the photo.
    • To remove the hard drive, detach it from the the hard drive connector. You can do this by pulling it gently with your hands.
  6. HP Compaq Presario cq62-214nr Keyboard Replacement, RAM: 步骤 6 中的图像 1,2 HP Compaq Presario cq62-214nr Keyboard Replacement, RAM: 步骤 6 中的图像 2,2
    • Remove the three M2.5x5 mm Phillips screws securing the memory case.
  7. HP Compaq Presario cq62-214nr Keyboard Replacement: 步骤 7 中的图像 1,2 HP Compaq Presario cq62-214nr Keyboard Replacement: 步骤 7 中的图像 2,2
    • Using a plastic opening tool, insert it alongside any openings on the case. Lift and slide the tool to remove the case.
  8. HP Compaq Presario cq62-214nr Keyboard Replacement: 步骤 8 中的图像 1,2 HP Compaq Presario cq62-214nr Keyboard Replacement: 步骤 8 中的图像 2,2
    • Remove the top RAM chip by lifting up and pulling it towards the left.
    • Once the top RAM chip is removed, remove the one underneath using the same method.
  9. HP Compaq Presario cq62-214nr Keyboard Replacement, Keyboard: 步骤 9 中的图像 1,2 HP Compaq Presario cq62-214nr Keyboard Replacement, Keyboard: 步骤 9 中的图像 2,2
    • With all the screws removed from the previous guides. Remove the final eight M2.5X5 mm Philips screws on the back of the laptop
  10. HP Compaq Presario cq62-214nr Keyboard Replacement: 步骤 10 中的图像 1,2 HP Compaq Presario cq62-214nr Keyboard Replacement: 步骤 10 中的图像 2,2
    • In the battery housing, there are three screws that hold the keyboard on. These screws are located on the side near the front.
    • In the center of the bottom of the computer between the RAM and the wifi antenna is a 4th keyboard screw that also needs to be removed.
  11. HP Compaq Presario cq62-214nr Keyboard Replacement: 步骤 11 中的图像 1,3 HP Compaq Presario cq62-214nr Keyboard Replacement: 步骤 11 中的图像 2,3 HP Compaq Presario cq62-214nr Keyboard Replacement: 步骤 11 中的图像 3,3
    • Open up the front of the laptop. Use a plastic opening tool to carefully pry open the keyboard from the edges.
  12. HP Compaq Presario cq62-214nr Keyboard Replacement: 步骤 12 中的图像 1,1
    • Remove the keyboard by pulling on it with your hands.
    • There is a ribbon cable that is still connected on the back of the keyboard. Do not pull off the ribbon cable when pulling up the keyboard.
  13. HP Compaq Presario cq62-214nr Keyboard Replacement: 步骤 13 中的图像 1,3 HP Compaq Presario cq62-214nr Keyboard Replacement: 步骤 13 中的图像 2,3 HP Compaq Presario cq62-214nr Keyboard Replacement: 步骤 13 中的图像 3,3
    • Locate the keyboard cable/wire that attaches the keyboard to the laptop .
    • Locate the latch of the wire connector
    • Unlatch the wire connector and gently pull out the wire with your hands
结论
Roth Marcelin
于10/06/16注册
726 声望
创作了6篇指南
团队
USF Tampa, Team 2-6, Sullivan Fall 2016 USF Tampa, Team 2-6, Sullivan Fall 2016 的会员
USFT-SULLIVAN-F16S2G6
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 22
总计 1,107
