简介
This guide will walk you through the process of accessing, removing and replacing the Disk Drive for a Compaq Presario V5303NR. The process of accessing the disk drive will need to be done for replacement if the disk drive is faulty or damaged.
你所需要的
Turn the laptop bottom-side up.
Push the battery latch to the left position to unlock the battery.
Remove the battery from its socket.
即将完成!
结论
