跳转到主内容
HP Compaq Presario V5303NR Battery Replacement
  1. HP Compaq Presario V5303NR Battery Replacement, Battery: 步骤 1 中的图像 1,2 HP Compaq Presario V5303NR Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • A switch is located below the battery, take your finger and push it over to the left.
    • The instruction to push the latch to the left is only relevant to the first image. The second image, which was included to provide a clearer image of said latch, would have the latch pushed to the right.
    • After this the battery should pop up and be dislodged
  2. HP Compaq Presario V5303NR Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the battery from its socket.
结论
Ryan Dunn
于03/18/18注册
197 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 134
