跳转到主内容
HP Compaq Presario CQ56-110US RAM Replacement
你所需要的
  1. HP Compaq Presario CQ56-110US RAM Replacement, RAM: 步骤 1 中的图像 1,1
    • Ensure the laptop is unplugged and completely powered off. Loosen the three small screws using a #1 Phillips screwdriver.
    • The screws do not come free from the panel. They only need to be loosened enough so the panel can be lifted/pried.
  2. HP Compaq Presario CQ56-110US RAM Replacement: 步骤 2 中的图像 1,1
    • Carefully pry the panel up using a plastic opening tool.
    • Pull the panel away from the laptop and set it off to the side.
  3. HP Compaq Presario CQ56-110US RAM Replacement: 步骤 3 中的图像 1,2 HP Compaq Presario CQ56-110US RAM Replacement: 步骤 3 中的图像 2,2
    • Locate the latches on the RAM
    • Push the latches away from the RAM
  4. HP Compaq Presario CQ56-110US RAM Replacement: 步骤 4 中的图像 1,1
    • Carefully pry the RAM upwards
    • Remove the RAM
结论
2等其他人完成本指南。
团队
USF Tampa, Team 8-4, Eyestone Spring 2017 USF Tampa, Team 8-4, Eyestone Spring 2017 的会员
USFT-EYESTONE-S17S8G4
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 13
总计 897
