跳转到主内容
修复你的物品
维修的权力
商店
简介
Use this guide to replace the entire keyboard if it is unresponsive or not functioning properly.
视频概述
  1. Ensure that the laptop is completely powered off, then flip it over to identify the battery latch located towards the bottom of the back panel. Push the latch to the unlocked position.
    • Ensure that the laptop is completely powered off, then flip it over to identify the battery latch located towards the bottom of the back panel.
    • Push the latch to the unlocked position.
  2. Gently take out the battery.
    • Gently take out the battery.
  3. On the back panel of the laptop are two screws which have a keyboard symbol next to them. Using a Phillips screwdriver with a  PH0 bit, remove both the 7mm and 5.5mm screws.
    • On the back panel of the laptop are two screws which have a keyboard symbol next to them.
    • Using a Phillips screwdriver with a PH0 bit, remove both the 7mm and 5.5mm screws.
  4. From left to right, unscrew the  5.5mm screw, the 7mm screw, and the 5.5mm screw located in the battery panel with the screwdriver. From left to right, unscrew the  5.5mm screw, the 7mm screw, and the 5.5mm screw located in the battery panel with the screwdriver.
    • From left to right, unscrew the 5.5mm screw, the 7mm screw, and the 5.5mm screw located in the battery panel with the screwdriver.
  5. Remove the RAM panel by unscrewing the three screws with the PH0 Screwdriver Bit. The screws do not come free from the panel. They only need to be loosened enough so that the panel can be lifted/pried using a plastic opening tool
    • Remove the RAM panel by unscrewing the three screws with the PH0 Screwdriver Bit.
    • The screws do not come free from the panel. They only need to be loosened enough so that the panel can be lifted/pried using a plastic opening tool
    • Remove the RAM panel using a plastic opening tool.
  6. Inside the RAM panel, use the screwdriver to remove the 5mm screw pictured.
    • Inside the RAM panel, use the screwdriver to remove the 5mm screw pictured.
  7. Flip the laptop back over and lift the lid to expose the keyboard.
    • Flip the laptop back over and lift the lid to expose the keyboard.
  8. Use a plastic opening tool to pry up the keyboard. Use a plastic opening tool to pry up the keyboard.
    • Use a plastic opening tool to pry up the keyboard.
  9. Once the keyboard is lifted, disconnect the band. Once the keyboard is lifted, disconnect the band.
    • Once the keyboard is lifted, disconnect the band.
结论
3等其他人完成本指南。
Iyonna L. Tynes
于2017年02月15日注册
439 信誉积分
创作了3篇指南
团队
USF Tampa, Team 8-4, Eyestone Spring 2017 USF Tampa, Team 8-4, Eyestone Spring 2017 的会员
USFT-EYESTONE-S17S8G4
4 名成员
创作了5篇指南
Difficulty HARD ? oh please… please change to EASY… just some screws?
Assembler Computer - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 4
过去的30天: 26
总计 2,500
