跳转到主内容
HP Compaq Presario CQ56-110US Keyboard Replacement
你所需要的
视频概述
  1. HP Compaq Presario CQ56-110US Keyboard Replacement, Battery: 步骤 1 中的图像 1,2 HP Compaq Presario CQ56-110US Keyboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Ensure that the laptop is completely powered off, then flip it over to identify the battery latch located towards the bottom of the back panel.
    • Push the latch to the unlocked position.
  2. HP Compaq Presario CQ56-110US Keyboard Replacement: 步骤 2 中的图像 1,1
    • Gently take out the battery.
  3. HP Compaq Presario CQ56-110US Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,2 HP Compaq Presario CQ56-110US Keyboard Replacement, Keyboard: 步骤 3 中的图像 2,2
    • On the back panel of the laptop are two screws which have a keyboard symbol next to them.
    • Using a Phillips screwdriver with a PH0 bit, remove both the 7mm and 5.5mm screws.
  4. HP Compaq Presario CQ56-110US Keyboard Replacement: 步骤 4 中的图像 1,2 HP Compaq Presario CQ56-110US Keyboard Replacement: 步骤 4 中的图像 2,2
    • From left to right, unscrew the 5.5mm screw, the 7mm screw, and the 5.5mm screw located in the battery panel with the screwdriver.
  5. HP Compaq Presario CQ56-110US Keyboard Replacement: 步骤 5 中的图像 1,2 HP Compaq Presario CQ56-110US Keyboard Replacement: 步骤 5 中的图像 2,2
    • Remove the RAM panel by unscrewing the three screws with the PH0 Screwdriver Bit.
    • The screws do not come free from the panel. They only need to be loosened enough so that the panel can be lifted/pried using a plastic opening tool
    • Remove the RAM panel using a plastic opening tool.
  6. HP Compaq Presario CQ56-110US Keyboard Replacement: 步骤 6 中的图像 1,1
    • Inside the RAM panel, use the screwdriver to remove the 5mm screw pictured.
  7. HP Compaq Presario CQ56-110US Keyboard Replacement: 步骤 7 中的图像 1,1
    • Flip the laptop back over and lift the lid to expose the keyboard.
  8. HP Compaq Presario CQ56-110US Keyboard Replacement: 步骤 8 中的图像 1,2 HP Compaq Presario CQ56-110US Keyboard Replacement: 步骤 8 中的图像 2,2
    • Use a plastic opening tool to pry up the keyboard.
  9. HP Compaq Presario CQ56-110US Keyboard Replacement: 步骤 9 中的图像 1,2 HP Compaq Presario CQ56-110US Keyboard Replacement: 步骤 9 中的图像 2,2
    • Once the keyboard is lifted, disconnect the band.
结论
3等其他人完成本指南。
Iyonna L. Tynes
于02/15/17注册
446 声望
创作了3篇指南
团队
USF Tampa, Team 8-4, Eyestone Spring 2017 USF Tampa, Team 8-4, Eyestone Spring 2017 的会员
USFT-EYESTONE-S17S8G4
4 名成员
创作了5篇指南
一条评论
Difficulty HARD ? oh please… please change to EASY… just some screws?
Assembler Computer - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 14
总计 3,483
