简介
Complete Disassembly of The Laptop excluding Laptop Display
你所需要的
Remove Ram Stick by pulling the tabs to it side
Remove the to remove the Wifi Card and remove its antenna wires
Remove 10 screws from the laptop
Remove 3 2.5 x 6.5 screws from the laptop
Remove 3 2.5 x 5 screws from the laptop
Remove 4 2.5 x 3 screws from the laptop
Remove the Ribbon Cables and Wires from the Motherboard and use a pick to remove the top cover
Remove 1 screw and lift up the top cover
Remove the Six Screws from the Heatsink
Remove the Cable of the fan
Laptop Dissasembly Complete, Here is Everything except for the Case and Display
To reassemble your device, follow these instructions in reverse order. This can be useful for a CPU Upgrade
6等其他人完成本指南。
一条评论
Thank you so much . I learned to unlock the device by following the illustrations
