跳转到主内容
HP Compaq Presario CQ56-110US CD Drive Replacement
你所需要的
  1. HP Compaq Presario CQ56-110US CD Drive Replacement, CD Drive: 步骤 1 中的图像 1,2 HP Compaq Presario CQ56-110US CD Drive Replacement, CD Drive: 步骤 1 中的图像 2,2
    • Loosen the two indicated screws on the panel using a Phillips screwdriver with a PH1 head size.
    • The screws do not come free from the panel. They only need to be loosened enough so that the panel can be lifted/pried using a plastic opening tool.
  2. HP Compaq Presario CQ56-110US CD Drive Replacement: 步骤 2 中的图像 1,1
    • Use the screwdriver to unscrew the four 5mm screws holding down the hard drive.
  3. HP Compaq Presario CQ56-110US CD Drive Replacement: 步骤 3 中的图像 1,2 HP Compaq Presario CQ56-110US CD Drive Replacement: 步骤 3 中的图像 2,2
    • Use plastic opening tools to lift up the hard drive. Set aside the hard drive without disconnecting the wire.
  4. HP Compaq Presario CQ56-110US CD Drive Replacement: 步骤 4 中的图像 1,1
    • Use a Phillips screwdriver with a PH0 head type to unscrew the indicated 5.5mm screw.
  5. HP Compaq Presario CQ56-110US CD Drive Replacement: 步骤 5 中的图像 1,1
    • Use plastic opening tools to pry open the CD Drive.
  6. HP Compaq Presario CQ56-110US CD Drive Replacement: 步骤 6 中的图像 1,1
    • Use your hands to pull the CD drive out and remove it from the laptop.
结论
另外一个人完成了本指南。
Iyonna L. Tynes
于02/15/17注册
446 声望
创作了3篇指南
团队
USF Tampa, Team 8-4, Eyestone Spring 2017 USF Tampa, Team 8-4, Eyestone Spring 2017 的会员
USFT-EYESTONE-S17S8G4
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 9
总计 805
