简介
To remove the touchpad, you must remove other components to get to it such as the keyboard.
你所需要的
Locate and unscrew the two screws on the back marked with a small keyboard. These screws hold the keyboard in place.
Locate the metal hooks where the keyboard connects to the laptop and use a metal spudger to gently pry up the keyboard.
Locate the twenty 3 mm Phillips head screws.
Unscrew them using the PH0 screwdriver.
Use the blow dryer to melt the adhesive around the edge of the touchpad.
The touchpad is now free to be removed.
Please add the last step of fixing a new touchpad with glue (what type of glue, how much is to be applied and the like.
Thanks
另外一个人完成了本指南。
