简介
In this guide, you will learn how to remove the keyboard of the HP Compaq C700 laptop.
你所需要的
Locate and unscrew the two screws on the back marked with a small keyboard. These screws hold the keyboard in place.
Locate the metal hooks where the keyboard connects to the laptop and use a metal spudger to gently pry up the keyboard.
另外一个人完成了本指南。
2条评论
there is a third screw holding in the keyboard located under the RAM cover not mentioned in this guide, please make sure you remove that too or else you may end up warping your keyboard like my friend did with his C700.
