跳转到主内容
HP Compaq C700 Keyboard Replacement
你所需要的
  1. HP Compaq C700 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • It is advised to work on the device only when it is powered off so as to avoid electrocution risks.
    • Turn off computer by pressing and holding the power button.
  2. HP Compaq C700 Keyboard Replacement: 步骤 2 中的图像 1,3 HP Compaq C700 Keyboard Replacement: 步骤 2 中的图像 2,3 HP Compaq C700 Keyboard Replacement: 步骤 2 中的图像 3,3
    • Locate and unscrew the two screws on the back marked with a small keyboard. These screws hold the keyboard in place.
    • Locate the metal hooks where the keyboard connects to the laptop and use a metal spudger to gently pry up the keyboard.
    There is a 3rd screw under ram door
    Noah Galegor - 回复
  3. HP Compaq C700 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Gently lift up and remove the keyboard.
结论
另外一个人完成了本指南。
Taylor Johansen
于10/20/16注册
690 声望
创作了5篇指南
团队
UMass Dartmouth, Team 5-6, Martin Fall 2016 UMass Dartmouth, Team 5-6, Martin Fall 2016 的会员
UMASSD-MARTIN-F16S5G6
3 名成员
创作了6篇指南
2条评论
er zijn 3 schroeven aan het keyboard
marcel - 回复
there is a third screw holding in the keyboard located under the RAM cover not mentioned in this guide, please make sure you remove that too or else you may end up warping your keyboard like my friend did with his C700.
Blackblur610 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 12
总计 773
