跳转到主内容
HP Compaq C700 Fan Replacement
你所需要的
  1. HP Compaq C700 Fan Replacement, Keyboard: 步骤 1 中的图像 1,1
    • It is advised to work on the device only when it is powered off so as to avoid electrocution risks.
    • Turn off computer by pressing and holding the power button.
  2. HP Compaq C700 Fan Replacement: 步骤 2 中的图像 1,3 HP Compaq C700 Fan Replacement: 步骤 2 中的图像 2,3 HP Compaq C700 Fan Replacement: 步骤 2 中的图像 3,3
    • Locate and unscrew the two screws on the back marked with a small keyboard. These screws hold the keyboard in place.
    • Locate the metal hooks where the keyboard connects to the laptop and use a metal spudger to gently pry up the keyboard.
  3. HP Compaq C700 Fan Replacement: 步骤 3 中的图像 1,1
    • Gently lift up and remove the keyboard.
  4. HP Compaq C700 Fan Replacement, Fan: 步骤 4 中的图像 1,1
    • Turn the laptop over so that you see the bottom.
    • Locate the twenty 3 mm Phillips head screws.
    • Unscrew them using the PH0 screwdriver
  5. HP Compaq C700 Fan Replacement: 步骤 5 中的图像 1,1
    • After unscrewing the 3 mm screws, remove the hard drive covering by lifting upward.
  6. HP Compaq C700 Fan Replacement: 步骤 6 中的图像 1,1
    • Remove the hard drive by pulling on the plastic tab and lifting upward.
  7. HP Compaq C700 Fan Replacement: 步骤 7 中的图像 1,1
    • Remove the covering that houses the RAM modules.
  8. HP Compaq C700 Fan Replacement: 步骤 8 中的图像 1,1
    • Locate and unscrew the two Phillips head 3 mm screws on the wireless card.
  9. HP Compaq C700 Fan Replacement: 步骤 9 中的图像 1,1
    • Unhook the two wires connecting to the wireless card by gently pulling them out.
  10. HP Compaq C700 Fan Replacement: 步骤 10 中的图像 1,1
    • Gently lift and pull out the card.
  11. HP Compaq C700 Fan Replacement: 步骤 11 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Locate the power button connector wire. (This can be found where the keyboard sits.)
    • Using the tweezers, unhook the wire.
  12. HP Compaq C700 Fan Replacement: 步骤 12 中的图像 1,2 HP Compaq C700 Fan Replacement: 步骤 12 中的图像 2,2
    • Press and hold the lock to pop the panel piece above the keyboard and pull up to remove it.
  13. HP Compaq C700 Fan Replacement: 步骤 13 中的图像 1,2 HP Compaq C700 Fan Replacement: 步骤 13 中的图像 2,2
    • Unplug the remaining wires using the tweezers.
  14. HP Compaq C700 Fan Replacement: 步骤 14 中的图像 1,1
    • Gently pull out the three wires.
  15. HP Compaq C700 Fan Replacement: 步骤 15 中的图像 1,2 HP Compaq C700 Fan Replacement: 步骤 15 中的图像 2,2
    • Locate the four 3 mm Phillips head screws.
    • Unscrew them using the PH0 screwdriver.
  16. HP Compaq C700 Fan Replacement: 步骤 16 中的图像 1,1
    • Unhook the display connector wire.
  17. HP Compaq C700 Fan Replacement: 步骤 17 中的图像 1,1
    • Gently disconnect the display by pulling it upwards.
  18. HP Compaq C700 Fan Replacement: 步骤 18 中的图像 1,1
    • Locate the disk drive on the side of the device.
    • Remove it by pulling it all the way out.
  19. HP Compaq C700 Fan Replacement: 步骤 19 中的图像 1,1
    • Use the PH0 screwdriver to remove the two 3 mm Phillips head screws in the disk drive port.
  20. HP Compaq C700 Fan Replacement: 步骤 20 中的图像 1,1
    • Locate and unplug the touchpad connection using the tweezers.
  21. HP Compaq C700 Fan Replacement: 步骤 21 中的图像 1,3 HP Compaq C700 Fan Replacement: 步骤 21 中的图像 2,3 HP Compaq C700 Fan Replacement: 步骤 21 中的图像 3,3
    • Using the Opening tool, gently pry up the cover and remove it.
  22. HP Compaq C700 Fan Replacement: 步骤 22 中的图像 1,1
    • Unplug the fan wire connection using the tweezers.
  23. HP Compaq C700 Fan Replacement: 步骤 23 中的图像 1,1
    • Locate the 3 mm Phillips head screw.
    • Unscrew it using the PH0 screwdriver.
  24. HP Compaq C700 Fan Replacement: 步骤 24 中的图像 1,2 HP Compaq C700 Fan Replacement: 步骤 24 中的图像 2,2
    • Using the opening tool, gently pry up and remove the fan.
结论
另外一个人完成了本指南。
Taylor Johansen
于10/20/16注册
690 声望
创作了5篇指南
团队
UMass Dartmouth, Team 5-6, Martin Fall 2016 UMass Dartmouth, Team 5-6, Martin Fall 2016 的会员
UMASSD-MARTIN-F16S5G6
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 18
总计 1,295
