跳转到主内容
HP Compaq C700 Battery Replacement
  1. HP Compaq C700 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • It is advised to work on the device only when it is powered off so as to avoid electrocution risks.
    • Turn off computer by pressing and holding the power button.
  2. HP Compaq C700 Battery Replacement: 步骤 2 中的图像 1,1
    • On the underside of the laptop, locate the sliding lock that keeps the battery in place.
    • Using your finger, slide the battery lock to the left to unlock the battery. Once the battery is unlocked, it is free to be removed.
结论
另外一个人完成了本指南。
Taylor Johansen
于10/20/16注册
690 声望
创作了5篇指南
团队
UMass Dartmouth, Team 5-6, Martin Fall 2016 UMass Dartmouth, Team 5-6, Martin Fall 2016 的会员
UMASSD-MARTIN-F16S5G6
3 名成员
创作了6篇指南
一条评论
thanks - appreciate this advice as I wasn’t able to get the battery out and thought I was missing something, but then I just tried harder!
Albert Einstein - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 23
总计 1,251
