跳转到主内容
HP Compaq 6730b Switch Cover Replacement
你所需要的
  1. HP Compaq 6730b Switch Cover Replacement, Switch Cover: 步骤 1 中的图像 1,3 HP Compaq 6730b Switch Cover Replacement, Switch Cover: 步骤 1 中的图像 2,3 HP Compaq 6730b Switch Cover Replacement, Switch Cover: 步骤 1 中的图像 3,3
    • Shut down the computer. Disconnect all external devices connected to the computer. Disconnect the power from the computer by first unplugging the power cord from the AC outlet and then unplugging the AC adapter from the computer.
    • Close the screen and turn the computer over. Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the computer. They are secured by a spring clip at the back, so they will not be easily removed. All that is required is to loosen those.
    • Turn the computer display-side up, with the front toward you. Open the computer as far as possible. There are four retention tabs that hold the keyboard down.
  2. HP Compaq 6730b Switch Cover Replacement: 步骤 2 中的图像 1,3 HP Compaq 6730b Switch Cover Replacement: 步骤 2 中的图像 2,3 HP Compaq 6730b Switch Cover Replacement: 步骤 2 中的图像 3,3
    • Use a small screwdriver, or other instrument, to slide the four tabs in a downward direction toward the palmrest.
    • Gently lift the keyboard up from the display side,
    • and tilt it toward the front of the computer. Do not lift it up to fast or to high, the keyboard ribbon cable is still connected
  3. HP Compaq 6730b Switch Cover Replacement: 步骤 3 中的图像 1,3 HP Compaq 6730b Switch Cover Replacement: 步骤 3 中的图像 2,3 HP Compaq 6730b Switch Cover Replacement: 步骤 3 中的图像 3,3
    • Here is the keyboard ribbon cable seated in the zero insertion force (Zif) connector. The keyboard is now separated and can now be removed.
    • Release the Zif connector to which the power button board cable is connected, by lifting the clasp of the Zif connector in an upward direction.
    • Lift the left and right sides of the switch cover until it detaches from the computer, but do not yet try to remove it.
  4. HP Compaq 6730b Switch Cover Replacement: 步骤 4 中的图像 1,2 HP Compaq 6730b Switch Cover Replacement: 步骤 4 中的图像 2,2
    • The LED board cable is still attached, disconnect it from the Zif connector by simply pulling it out in an upward direction.
    • With both ribbon cables disconnected, remove the switch cover.
结论
5等其他人完成本指南。
oldturkey03
于09/29/10注册
782,145 声望
创作了119篇指南
团队
Global Fixers Global Fixers 的会员
Community
33 名成员
创作了537篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 2,369
