简介
The fan is a straight forward removal once the keyboard and the button bar are removed. This will help for either a fan replacement or just to clean it out.
配件
无需配件。
  1. Shut down the computer. Disconnect all external devices connected to the computer. Disconnect the power from the computer by first unplugging the power cord from the AC outlet and then unplugging the AC adapter from the computer. Close the screen and turn the computer over. Remove the battery by sliding the locking clip to the left and then pulling the battery from the case. Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the computer. They are secured by a spring clip at the back, so they will not be easily removed. All that is required is to loosen those.
    • Shut down the computer. Disconnect all external devices connected to the computer. Disconnect the power from the computer by first unplugging the power cord from the AC outlet and then unplugging the AC adapter from the computer.
    • Close the screen and turn the computer over. Remove the battery by sliding the locking clip to the left and then pulling the battery from the case.
    • Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the computer. They are secured by a spring clip at the back, so they will not be easily removed. All that is required is to loosen those.
  2. Turn the computer display-side up, with the front toward you. Open the computer as far as possible. There are four retention tabs that hold the keyboard down. Use a small screwdriver, or other instrument, to slide the four tabs in a downward direction toward the palmrest. Gently lift the keyboard up from the display side,
    • Turn the computer display-side up, with the front toward you. Open the computer as far as possible. There are four retention tabs that hold the keyboard down.
    • Use a small screwdriver, or other instrument, to slide the four tabs in a downward direction toward the palmrest.
    • Gently lift the keyboard up from the display side,
  3. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  4. and tilt it toward the front of the computer. Do not lift it up to fast or to high, the keyboard ribbon cable is still connected Here is the keyboard ribbon cable seated in the zero insertion force (Zif) connector. Move the clip that looks the cable into the connector in an upward direction and remove the cable. The keyboard is now separated and can be removed.
    • and tilt it toward the front of the computer. Do not lift it up to fast or to high, the keyboard ribbon cable is still connected
    • Here is the keyboard ribbon cable seated in the zero insertion force (Zif) connector. Move the clip that looks the cable into the connector in an upward direction and remove the cable.
    • The keyboard is now separated and can be removed.
  5. Release the Zif connector to which the power button board cable is connected, by lifting the clasp of the Zif connector in an upward direction. Lift the left and right sides of the switch cover until it detaches from the computer, but do not yet try to remove it. The LED board cable is still attached, disconnect it from the Zif connector by simply pulling it out in an upward direction.
    • Release the Zif connector to which the power button board cable is connected, by lifting the clasp of the Zif connector in an upward direction.
    • Lift the left and right sides of the switch cover until it detaches from the computer, but do not yet try to remove it.
    • The LED board cable is still attached, disconnect it from the Zif connector by simply pulling it out in an upward direction.
  6. Remove the fan connector. (it is not necessary to use forceps or any other tool) Loosen the two Phillips 2.5×7.0 screws that secure the fan to the base enclosure. Remove the fan from the case.
    • Remove the fan connector. (it is not necessary to use forceps or any other tool)
    • Loosen the two Phillips 2.5×7.0 screws that secure the fan to the base enclosure.
    • Remove the fan from the case.
结论
2等其他人完成本指南。
oldturkey03
于2010年09月29日注册
558,950 信誉积分
创作了101篇指南
团队
OTS OTS 的会员
Business
1 名成员
创作了123篇指南
Thanks a million for this. My lap top is… old. Fan has been swirling away like crazy for years. Just followed your advice and it sounds like new.
Kind regards,
Gill
Gillian Potter - 回复
浏览统计数据:
过去的24小时: 12
过去的7天: 19
过去的30天: 67
总计 5,755
