跳转到主内容
HP Compaq 6710b Power Button Panel Replacement
你所需要的
  1. HP Compaq 6710b Power Button Panel Replacement, Keyboard: 步骤 1 中的图像 1,3 HP Compaq 6710b Power Button Panel Replacement, Keyboard: 步骤 1 中的图像 2,3 HP Compaq 6710b Power Button Panel Replacement, Keyboard: 步骤 1 中的图像 3,3
    • Turn off computer before starting.
    • Flip to the backside of the laptop.
    • Using a Phillips #1 screwdriver, unscrew the 5mm screw and take off the shown cover.
    • Using the same screwdriver, unscrew the 8mm screws.
    • The screws may not completely fall out of the laptop, just ensure they are unscrewed as far as they will go.
  2. HP Compaq 6710b Power Button Panel Replacement: 步骤 2 中的图像 1,1
    • Flip over the laptop to the top side, and open the laptop.
    • Slide the locking tabs down using a blue plastic opening tool or your fingernail.
  3. HP Compaq 6710b Power Button Panel Replacement: 步骤 3 中的图像 1,2 HP Compaq 6710b Power Button Panel Replacement: 步骤 3 中的图像 2,2
    • Using the plastic prying tool, lift the keyboard gently towards you.
    • Don't take the keyboard completely off because it is still attached with a ribbon cable to the computer.
  4. HP Compaq 6710b Power Button Panel Replacement: 步骤 4 中的图像 1,1
    • Pull up on both sides of the black locking tab of the connector.
    • The keyboard should now be free of the computer.
  5. HP Compaq 6710b Power Button Panel Replacement, Power Button Panel: 步骤 5 中的图像 1,1
    • Put a finger under each side of the plastic lock on the ribbon cable and pull up.
  6. HP Compaq 6710b Power Button Panel Replacement: 步骤 6 中的图像 1,3 HP Compaq 6710b Power Button Panel Replacement: 步骤 6 中的图像 2,3 HP Compaq 6710b Power Button Panel Replacement: 步骤 6 中的图像 3,3
    • Using a flathead screwdriver, get under each plastic hinge cover until they pop.
    • Lift the right edge of plastic strip covering the power button and gently pull it up until the whole strip comes free.
结论
4等其他人完成本指南。
Khulan Orgil
于04/14/15注册
1,171 声望
创作了6篇指南
团队
Cal Poly, Team 4-2, Maness Spring 2015 Cal Poly, Team 4-2, Maness Spring 2015 的会员
CPSU-MANESS-S15S4G2
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 30
总计 3,406
