你所需要的
Flip the computer over so the backside is facing you.
Using the two prongs that are located in the back, slide the further left prong and the upper right prong to the left as indicated in the image.
Slide the battery out.
Flip the laptop over and locate the sign that says HP 3D DriveGuard.
Remove the two 5mm JIS #1 screws with your screwdriver.
Carefully lift up the cover.
Carefully lift up the hard drive from the back and pull it out.
2等其他人完成本指南。
