跳转到主内容
HP Compaq 6510b Hard Drive Replacement
你所需要的
  1. HP Compaq 6510b Hard Drive Replacement, Battery: 步骤 1 中的图像 1,2 HP Compaq 6510b Hard Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Flip the computer over so the backside is facing you.
    • Using the two prongs that are located in the back, slide the further left prong and the upper right prong to the left as indicated in the image.
    • Slide the battery out.
  2. HP Compaq 6510b Hard Drive Replacement, Hard Drive: 步骤 2 中的图像 1,3 HP Compaq 6510b Hard Drive Replacement, Hard Drive: 步骤 2 中的图像 2,3 HP Compaq 6510b Hard Drive Replacement, Hard Drive: 步骤 2 中的图像 3,3
    • Flip the laptop over and locate the sign that says HP 3D DriveGuard.
    • Remove the two 5mm JIS #1 screws with your screwdriver.
    • Carefully lift up the cover.
    • Carefully lift up the hard drive from the back and pull it out.
结论
2等其他人完成本指南。
Joseph Noudom
于03/01/18注册
569 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 18
总计 897
