跳转到主内容
HP Compaq 2510p WiFi Card Replacement
你所需要的
  1. HP Compaq 2510p WiFi Card Replacement, WiFi Card: 步骤 1 中的图像 1,1
    • Flip the laptop over and locate the RAM cover plate towards the left of the laptop. There will be two screws located on the panel.
  2. HP Compaq 2510p WiFi Card Replacement: 步骤 2 中的图像 1,1
    • Using your Philips screwdriver, unscrew both screws.
  3. HP Compaq 2510p WiFi Card Replacement: 步骤 3 中的图像 1,1
    • Lift the plate with your finger to remove it.
  4. HP Compaq 2510p WiFi Card Replacement: 步骤 4 中的图像 1,2 HP Compaq 2510p WiFi Card Replacement: 步骤 4 中的图像 2,2
    • Locate the screws at the top of the card and use your Philips screwdriver to remove them.
    • Be sure to ground yourself before touching components.
  5. HP Compaq 2510p WiFi Card Replacement: 步骤 5 中的图像 1,1
    • Lift the card from underneath the top, using the spudger to leverage the card upwards. Then pull to release the card.
    • Always used ESD safe tools when repairing electronics. The black nylon spudger should be used whenever possible.
  6. HP Compaq 2510p WiFi Card Replacement: 步骤 6 中的图像 1,1
    • Pull on each of the wires connected to the card. They will easily pop off and the WiFi card will be released.
结论
另外一个人完成了本指南。
Dan Champagne
于10/21/16注册
184 声望
创作了2篇指南
团队
UMass Dartmouth, Team 3-8, Isaacson Fall 2016 UMass Dartmouth, Team 3-8, Isaacson Fall 2016 的会员
UMASSD-ISAACSON-F16S3G8
3 名成员
创作了5篇指南
一条评论
what wifi cards does this notebook support?
plaui - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 8
总计 643
