跳转到主内容
HP Compaq 2510p RAM Replacement
你所需要的
  1. HP Compaq 2510p RAM Replacement, RAM: 步骤 1 中的图像 1,1
    • Flip the device over so the back panel is facing upwards. Locate the RAM plate cover towards the left side of the laptop. There will be two screws located on the panel.
  2. HP Compaq 2510p RAM Replacement: 步骤 2 中的图像 1,1
    • Remove both screws holding the RAM cover plate in place using your Phillips Screwdriver.
  3. HP Compaq 2510p RAM Replacement: 步骤 3 中的图像 1,1
    • Remove the cover plate by lifting upwards once screws are removed.
  4. HP Compaq 2510p RAM Replacement: 步骤 4 中的图像 1,1
    • Carefully release the pins that are securing the RAM in place by pushing in a outward motion, away from the RAM.
    • Be sure to ground yourself before touching the RAM.
    • Be gentle when releasing the pins.
  5. HP Compaq 2510p RAM Replacement: 步骤 5 中的图像 1,1
    • Remove the old RAM by lifting it upwards, then pulling.
结论
2等其他人完成本指南。
团队
UMass Dartmouth, Team 3-8, Isaacson Fall 2016 UMass Dartmouth, Team 3-8, Isaacson Fall 2016 的会员
UMASSD-ISAACSON-F16S3G8
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 795
