跳转到主内容
HP Color LaserJet Pro MFP M277dw Wireless Card Replacement
你所需要的
  1. HP Color LaserJet Pro MFP M277dw Wireless Card Replacement, Wireless Card: 步骤 1 中的图像 1,1
    • Remove paper tray by pulling it straight out.
    • The tray should just slide out with little to no resistance.
  2. HP Color LaserJet Pro MFP M277dw Wireless Card Replacement: 步骤 2 中的图像 1,3 HP Color LaserJet Pro MFP M277dw Wireless Card Replacement: 步骤 2 中的图像 2,3 HP Color LaserJet Pro MFP M277dw Wireless Card Replacement: 步骤 2 中的图像 3,3
    • Lower the back panel by pulling it down from the upright position.
    • Remove one Phillips #2 10mm screw.
    • Use the plastic opening tool to remove the left side panel.
    • Flipping the printer onto its side makes it easier to remove the panel and access the motherboard.
  3. HP Color LaserJet Pro MFP M277dw Wireless Card Replacement: 步骤 3 中的图像 1,2 HP Color LaserJet Pro MFP M277dw Wireless Card Replacement: 步骤 3 中的图像 2,2
    • Remove one Phillips #2 11mm screw.
    • Remove the wireless card.
    • The wireless card is connected to the circuit board with pins, it will take a bit of force to remove it.
结论
2等其他人完成本指南。
团队
Cal Poly, Team S4-G2, White Fall 2018 Cal Poly, Team S4-G2, White Fall 2018 的会员
CPSU-WHITE-F18S4G2
3 名成员
创作了10篇指南
3条评论
Would you share the part number of the module, better off a link to where it is sold. Thanks.
Jonathan Chan - 回复
can this wireless card be upgraded to say a more modern one where it accepts wap3?
BenGie Cruz - 回复
I’m just curious if you’ve ever left off the WiFi card and powered it up. Does the printer take away the entry for wifi settings on the display if you do this?
Jonathan Wolff - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 10
过去 30 天: 43
总计 3,869
