跳转到主内容
HP Color LaserJet Pro MFP M277dw Power Module Replacement
你所需要的
  1. HP Color LaserJet Pro MFP M277dw Power Module  Replacement, Power Module: 步骤 1 中的图像 1,3 HP Color LaserJet Pro MFP M277dw Power Module  Replacement, Power Module: 步骤 1 中的图像 2,3 HP Color LaserJet Pro MFP M277dw Power Module  Replacement, Power Module: 步骤 1 中的图像 3,3
    • Open and lower the back panel by pulling it down.
    • Remove one Phillips #2 10 mm screw.
  2. HP Color LaserJet Pro MFP M277dw Power Module  Replacement: 步骤 2 中的图像 1,3 HP Color LaserJet Pro MFP M277dw Power Module  Replacement: 步骤 2 中的图像 2,3 HP Color LaserJet Pro MFP M277dw Power Module  Replacement: 步骤 2 中的图像 3,3
    • Use the plastic opening tool to remove the right side panel of the printer.
    • Flipping the printer on its side, with the right side facing up, will make it easier to remove.
  3. HP Color LaserJet Pro MFP M277dw Power Module  Replacement: 步骤 3 中的图像 1,3 HP Color LaserJet Pro MFP M277dw Power Module  Replacement: 步骤 3 中的图像 2,3 HP Color LaserJet Pro MFP M277dw Power Module  Replacement: 步骤 3 中的图像 3,3
    • Remove two Phillips #2 12mm screws.
    • Remove four different pin connectors that attach to the power module located at the bottom.
    • Removing the white connector is made easier with assistance of a spudger/flat tip that loosens the clamp.
  4. HP Color LaserJet Pro MFP M277dw Power Module  Replacement: 步骤 4 中的图像 1,2 HP Color LaserJet Pro MFP M277dw Power Module  Replacement: 步骤 4 中的图像 2,2
    • Remove two Phillips #2 10mm from the left (front) and right (back) side that attach the power module to the printer.
  5. HP Color LaserJet Pro MFP M277dw Power Module  Replacement: 步骤 5 中的图像 1,3 HP Color LaserJet Pro MFP M277dw Power Module  Replacement: 步骤 5 中的图像 2,3 HP Color LaserJet Pro MFP M277dw Power Module  Replacement: 步骤 5 中的图像 3,3
    • Slowly lift the power module from the printer using both hands.
结论
3等其他人完成本指南。
团队
Cal Poly, Team S4-G2, White Fall 2018 Cal Poly, Team S4-G2, White Fall 2018 的会员
CPSU-WHITE-F18S4G2
3 名成员
创作了10篇指南
2条评论
Hello, wäre can i buy the power supply? Thank you
Jakob Hetzendorfer - 回复
Thanks a lot - also works for model M281fdw
patrik maurer - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 13
过去 30 天: 80
总计 4,251
