跳转到主内容
HP Color LaserJet Pro MFP M277dw Power Button Replacement
你所需要的
  1. HP Color LaserJet Pro MFP M277dw Power Button Replacement, Power Button: 步骤 1 中的图像 1,3 HP Color LaserJet Pro MFP M277dw Power Button Replacement, Power Button: 步骤 1 中的图像 2,3 HP Color LaserJet Pro MFP M277dw Power Button Replacement, Power Button: 步骤 1 中的图像 3,3
    • Lower the back panel by pulling it down.
    • Remove one Phillips #2 10mm screw.
    • Use the plastic opening tool to remove right side panel by prying it off.
    • Flipping the printer onto its side makes it easier to remove the side panel.
  2. HP Color LaserJet Pro MFP M277dw Power Button Replacement: 步骤 2 中的图像 1,2 HP Color LaserJet Pro MFP M277dw Power Button Replacement: 步骤 2 中的图像 2,2
    • Lower the front panel by pulling it down from the upright position.
    • The button cover should come off with the panel, if it does not be sure to remove it.
  3. HP Color LaserJet Pro MFP M277dw Power Button Replacement: 步骤 3 中的图像 1,3 HP Color LaserJet Pro MFP M277dw Power Button Replacement: 步骤 3 中的图像 2,3 HP Color LaserJet Pro MFP M277dw Power Button Replacement: 步骤 3 中的图像 3,3
    • Remove two Phillips #2 8mm screws.
    • Unplug the wire connecting the power button to the circuit board by gently pulling them apart.
结论
另外一个人完成了本指南。
团队
Cal Poly, Team S4-G2, White Fall 2018 Cal Poly, Team S4-G2, White Fall 2018 的会员
CPSU-WHITE-F18S4G2
3 名成员
创作了10篇指南
2条评论
How to make the catridge tray out ? As one side(left) of the tray is not coming out.
Ajay Kumar Singh - 回复
I am not sure if it’s the power button or power module. How do I determine that? Where do I get the parts?
Sheila Shook - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 37
总计 2,595
