跳转到主内容
HP Chromebox J5N50UT Bottom Shield Replacement
你所需要的
  1. HP Chromebox J5N50UT Bottom Shield Replacement, Bottom Cover: 步骤 1 中的图像 1,1
    • Before removing the bottom cover, ensure that your computer is powered down and ensure that all external devices are disconnected. If you are unsure whether the computer is off or in hibernation mode, turn the computer on, then shut it down through the operating system.
    • Position the device upside-down on a flat, level surface with the USB ports facing you.
  2. HP Chromebox J5N50UT Bottom Shield Replacement: 步骤 2 中的图像 1,1
    • Using your metal spudger, lift and remove the 4 rubber “feet” from each corner.
  3. HP Chromebox J5N50UT Bottom Shield Replacement: 步骤 3 中的图像 1,1
    • Using your Phillips head screwdriver, remove the four Phillips M2.5×4.0 screws that secure the bottom cover to the computer. In this step the usage of the magnetic mat will be helpful to keep up with the screws.
  4. HP Chromebox J5N50UT Bottom Shield Replacement: 步骤 4 中的图像 1,1
    • Insert the flat end of your metal spudger under the bottom cover near the USB ports, then pry the bottom cover off the computer.
  5. HP Chromebox J5N50UT Bottom Shield Replacement, Bottom Shield: 步骤 5 中的图像 1,1
    • Lift the two pieces of mylar tape from the bracket.
  6. HP Chromebox J5N50UT Bottom Shield Replacement: 步骤 6 中的图像 1,1
    • Using your Phillips #1 screwdriver, remove the four Phillips M2.5×4.0 screws that hold the shield in place.
  7. HP Chromebox J5N50UT Bottom Shield Replacement: 步骤 7 中的图像 1,1
    • Insert your spudger into the gap between the bottom shield and the ports and gently pry to lift and remove the shield.
结论
Ashley Marvin
于09/06/18注册
685 声望
创作了5篇指南
团队
Ohio State, Team S1-G3, Whitney Fall 2018 Ohio State, Team S1-G3, Whitney Fall 2018 的会员
OSU-WHITNEY-F18S1G3
2 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 501
