简介
If the bottom cover of your HP Chromebox is damaged, it is easy to replace. This guide will take you through the steps of replacing the bottom cover. For this guide, you will need the Phillips #1 screwdriver and a plastic spudger.
你所需要的
Position the device upside-down on a flat, level surface with the USB ports facing you.
即将完成!
结论
另外一个人完成了本指南。
