跳转到主内容
HP Chromebook x360 14-da0011dx Lower Case Replacement
你所需要的
  1. HP Chromebook x360 14-da0011dx Lower Case Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Flip the device over with the hinge facing away from you.
    • On the back of the device, remove the two rubber strips on the top and the bottom of the device using a spudger.
  2. HP Chromebook x360 14-da0011dx Lower Case Replacement: 步骤 2 中的图像 1,2 HP Chromebook x360 14-da0011dx Lower Case Replacement: 步骤 2 中的图像 2,2
    • Remove the seven 8.0 mm screws located under the two rubber pads and the screws along the back of the device using a Phillips #1 screwdriver.
  3. HP Chromebook x360 14-da0011dx Lower Case Replacement: 步骤 3 中的图像 1,3 HP Chromebook x360 14-da0011dx Lower Case Replacement: 步骤 3 中的图像 2,3 HP Chromebook x360 14-da0011dx Lower Case Replacement: 步骤 3 中的图像 3,3
    • Use a spudger to gently pry the edges of the back cover off the device. Slowly work all the way around the device until the panel comes loose.
结论
另外一个人完成了本指南。
一条评论
Where to get replacement parts for this one?
Aguinaldo Motta - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 60
总计 376
