跳转到主内容
HP Chromebook x360 14-da0011dx Battery Replacement
你所需要的
  1. HP Chromebook x360 14-da0011dx Battery Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Flip the device over with the hinge facing away from you.
    • On the back of the device, remove the two rubber strips on the top and the bottom of the device using a spudger.
  2. HP Chromebook x360 14-da0011dx Battery Replacement: 步骤 2 中的图像 1,2 HP Chromebook x360 14-da0011dx Battery Replacement: 步骤 2 中的图像 2,2
    • Remove the seven 8.0 mm screws located under the two rubber pads and the screws along the back of the device using a Phillips #1 screwdriver.
  3. HP Chromebook x360 14-da0011dx Battery Replacement: 步骤 3 中的图像 1,3 HP Chromebook x360 14-da0011dx Battery Replacement: 步骤 3 中的图像 2,3 HP Chromebook x360 14-da0011dx Battery Replacement: 步骤 3 中的图像 3,3
    • Use a spudger to gently pry the edges of the back cover off the device. Slowly work all the way around the device until the panel comes loose.
  4. HP Chromebook x360 14-da0011dx Battery Replacement, Battery: 步骤 4 中的图像 1,2 HP Chromebook x360 14-da0011dx Battery Replacement, Battery: 步骤 4 中的图像 2,2
    • Remove the cable attached to the battery.
  5. HP Chromebook x360 14-da0011dx Battery Replacement: 步骤 5 中的图像 1,2 HP Chromebook x360 14-da0011dx Battery Replacement: 步骤 5 中的图像 2,2
    • Remove the five 3.0 mm screws holding the battery in place using the Phillips #1 screwdriver.
  6. HP Chromebook x360 14-da0011dx Battery Replacement: 步骤 6 中的图像 1,1
    • Lift the battery out of the chassis.
结论
另外一个人完成了本指南。
Jared Tallent
于02/14/23注册
196 声望
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 37
总计 638
