跳转到主内容
HP Chromebook x360 11-ae010nr Display Replacement
你所需要的
  1. HP Chromebook x360 11-ae010nr Display Replacement, Keyboard: 步骤 1 中的图像 1,2 HP Chromebook x360 11-ae010nr Display Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Flip the device upside down so that the screws are visible.
    • Loosen two captive Phillips #1 screws from the center of the device.
    • Remove three 9.3 mm Phillips #1 screws from the joint side of the device.
    • Remove four 6.1 mm Phillips #1 screws from the opening side of the device.
  2. HP Chromebook x360 11-ae010nr Display Replacement: 步骤 2 中的图像 1,3 HP Chromebook x360 11-ae010nr Display Replacement: 步骤 2 中的图像 2,3 HP Chromebook x360 11-ae010nr Display Replacement: 步骤 2 中的图像 3,3
    • Insert an iFixit opening tool between the edge of the keyboard assembly and the base of the device.
    • Push down on the handle of the opening tool to create an opening between the keyboard assembly and the base of the device.
    • Move the opening tool around the device, popping open the clips with force when necessary, until the keyboard assembly is fully lifted from the base of the device.
  3. HP Chromebook x360 11-ae010nr Display Replacement: 步骤 3 中的图像 1,2 HP Chromebook x360 11-ae010nr Display Replacement: 步骤 3 中的图像 2,2
    • Separate the keyboard assembly and the case.
    • Two cables connect the keyboard to the device, so take caution to not damage these cables.
    • Flip the black plastic tab where the wider cable meets the main board using the tip of a spudger or a fingernail.
    • Remove the cable with curved needle nose pliers or your fingers.
  4. HP Chromebook x360 11-ae010nr Display Replacement: 步骤 4 中的图像 1,2 HP Chromebook x360 11-ae010nr Display Replacement: 步骤 4 中的图像 2,2
    • Flip the white plastic tab where the thinner cable meets the main board using the tip of a spudger or a fingernail.
    • Separate the keyboard from the laptop.
  5. HP Chromebook x360 11-ae010nr Display Replacement, Display: 步骤 5 中的图像 1,3 HP Chromebook x360 11-ae010nr Display Replacement, Display: 步骤 5 中的图像 2,3 HP Chromebook x360 11-ae010nr Display Replacement, Display: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use a pair of tweezers to gently but firmly pull each of the black cables out from their sockets.
  6. HP Chromebook x360 11-ae010nr Display Replacement: 步骤 6 中的图像 1,3 HP Chromebook x360 11-ae010nr Display Replacement: 步骤 6 中的图像 2,3 HP Chromebook x360 11-ae010nr Display Replacement: 步骤 6 中的图像 3,3
    • Use a pair of tweezers to partially peel and hold both plastic strips away from the golden connector cable.
    • Use an opening tool to pull the golden cable out from its socket.
  7. HP Chromebook x360 11-ae010nr Display Replacement: 步骤 7 中的图像 1,3 HP Chromebook x360 11-ae010nr Display Replacement: 步骤 7 中的图像 2,3 HP Chromebook x360 11-ae010nr Display Replacement: 步骤 7 中的图像 3,3
    • Use a pair of tweezers to gently pull back and hold the plastic strip.
    • Pull the black cable out from its socket.
  8. HP Chromebook x360 11-ae010nr Display Replacement: 步骤 8 中的图像 1,3 HP Chromebook x360 11-ae010nr Display Replacement: 步骤 8 中的图像 2,3 HP Chromebook x360 11-ae010nr Display Replacement: 步骤 8 中的图像 3,3
    • Use a pair of tweezers to flip up the white clip.
    • Gently remove the white and blue ribbon cable from its socket.
  9. HP Chromebook x360 11-ae010nr Display Replacement: 步骤 9 中的图像 1,3 HP Chromebook x360 11-ae010nr Display Replacement: 步骤 9 中的图像 2,3 HP Chromebook x360 11-ae010nr Display Replacement: 步骤 9 中的图像 3,3
    • Remove the two 6 mm Phillips #0 screws from the metal bracket on the left side of the device.
    • Remove the two 6 mm Phillips #0 screws from the metal bracket on the right side of the device.
  10. HP Chromebook x360 11-ae010nr Display Replacement: 步骤 10 中的图像 1,3 HP Chromebook x360 11-ae010nr Display Replacement: 步骤 10 中的图像 2,3 HP Chromebook x360 11-ae010nr Display Replacement: 步骤 10 中的图像 3,3
    • Carefully pull the display towards you while keeping the both brackets parallel to the body of the device.
    • Keep wires out of the way as they can be easily damaged when removing the display.
结论
另外一个人完成了本指南。
jonas wojtas
于10/25/19注册
216 声望
撰写一个指南
团队
UMass Dartmouth, Team S1-G9, O'Connell Fall 2019 UMass Dartmouth, Team S1-G9, O'Connell Fall 2019 的会员
UMASSD-O'CONNELL-F19S1G9
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 7
过去 30 天: 14
总计 1,669
