跳转到主内容
HP Chromebook CB2L Trackpad Replacement
你所需要的
  1. HP Chromebook CB2L Trackpad Replacement, Trackpad: 步骤 1 中的图像 1,3 HP Chromebook CB2L Trackpad Replacement, Trackpad: 步骤 1 中的图像 2,3 HP Chromebook CB2L Trackpad Replacement, Trackpad: 步骤 1 中的图像 3,3
    • Flip the Chromebook over, and starting at the top right or left hand corner of the large blue piece, use the plastic opening tool to remove it.
    • Remove six 4.77mm screws using the Phillips #1 screwdriver.
    • This part has fragile plastic connectors on it. Do not damage them.
  2. HP Chromebook CB2L Trackpad Replacement: 步骤 2 中的图像 1,3 HP Chromebook CB2L Trackpad Replacement: 步骤 2 中的图像 2,3 HP Chromebook CB2L Trackpad Replacement: 步骤 2 中的图像 3,3
    • Starting at either the top left or right hand corner of the exposed metal piece, use the blue plastic opening tool to remove the back panel.
  3. HP Chromebook CB2L Trackpad Replacement: 步骤 3 中的图像 1,2 HP Chromebook CB2L Trackpad Replacement: 步骤 3 中的图像 2,2
    • Remove four 3.42mm screws using the Phillips #1 screwdriver.
    • Disconnect the battery from the motherboard.
    • Remove the battery.
  4. HP Chromebook CB2L Trackpad Replacement: 步骤 4 中的图像 1,1
    • Remove four 2.57mm screws using the Phillips #1 screwdriver.
    • Remove single 2.43mm screw using the Phillips #1 screwdriver.
  5. HP Chromebook CB2L Trackpad Replacement: 步骤 5 中的图像 1,3 HP Chromebook CB2L Trackpad Replacement: 步骤 5 中的图像 2,3 HP Chromebook CB2L Trackpad Replacement: 步骤 5 中的图像 3,3
    • Remove the metal piece along the bottom of the trackpad.
    • Use the plastic opening tool to carefully flip the black piece on the ribbon cable holder then remove the ribbon cable.
    • Push the trackpad out from the keyboard side.
结论
Nathan Petrie
于10/31/18注册
277 声望
创作了2篇指南
团队
IUPUI, Team S1-G4, Harley Fall 2018 IUPUI, Team S1-G4, Harley Fall 2018 的会员
IUPUI-HARLEY-F18S1G4
3 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 135
