跳转到主内容
HP Chromebook CB2L Speaker Replacement
你所需要的
  1. HP Chromebook CB2L Speaker Replacement, Battery: 步骤 1 中的图像 1,2 HP Chromebook CB2L Speaker Replacement, Battery: 步骤 1 中的图像 2,2
    • First flip your HP Chromebook CB2L over such that the bottom is facing upwards.
    • Next, using the plastic opening tool remove the blue panel.
  2. HP Chromebook CB2L Speaker Replacement: 步骤 2 中的图像 1,3 HP Chromebook CB2L Speaker Replacement: 步骤 2 中的图像 2,3 HP Chromebook CB2L Speaker Replacement: 步骤 2 中的图像 3,3
    • Using the Phillips #1 screwdriver, remove the six 1.2mm screws.
    • Gently pry off the white back panel using the plastic opening tool.
  3. HP Chromebook CB2L Speaker Replacement: 步骤 3 中的图像 1,1
    • Disconnect the battery input to the motherboard using the plastic opening tool
  4. HP Chromebook CB2L Speaker Replacement: 步骤 4 中的图像 1,1
    • Unscrew the four 1.2mm screws using the Phillips #1 screwdriver.
  5. HP Chromebook CB2L Speaker Replacement: 步骤 5 中的图像 1,1
    • Using the plastic opening tool remove the battery from the Chromebook.
  6. HP Chromebook CB2L Speaker Replacement, Speaker: 步骤 6 中的图像 1,1
    • Using the plastic opening tool lift the black tab.
    • Disconnect the blue and black strip from the motherboard.
  7. HP Chromebook CB2L Speaker Replacement: 步骤 7 中的图像 1,1
    • Use the Phillips #1 screwdriver to remove the four 1.2mm screws circled red.
  8. HP Chromebook CB2L Speaker Replacement: 步骤 8 中的图像 1,3 HP Chromebook CB2L Speaker Replacement: 步骤 8 中的图像 2,3 HP Chromebook CB2L Speaker Replacement: 步骤 8 中的图像 3,3
    • Gently pull the black wire to disconnect the audio port from the motherboard.
    • Disconnect the black wire connecting the speaker to the motherboard with caution.
  9. HP Chromebook CB2L Speaker Replacement: 步骤 9 中的图像 1,1
    • Use the plastic opening tool to remove the speaker from back panel.
结论
Gregory Hinkson
于02/13/17注册
352 声望
创作了3篇指南
团队
USF Tampa, Team S2-G6, Lacy Spring 2017 USF Tampa, Team S2-G6, Lacy Spring 2017 的会员
USFT-LACY-S17S2G6
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 7
总计 153
