跳转到主内容
HP Chromebook CB2L Keyboard Replacement
你所需要的
  1. HP Chromebook CB2L Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Flip the Chromebook over so the blue panels are showing.
    • Starting in the top left or right corner, use the plastic opening tool to remove the large blue panel.
    • This piece has fragile plastic connectors. Don't damage them.
  2. HP Chromebook CB2L Keyboard Replacement: 步骤 2 中的图像 1,2 HP Chromebook CB2L Keyboard Replacement: 步骤 2 中的图像 2,2
    • Remove six 4.77mm screws using the Phillips #1 screwdriver.
  3. HP Chromebook CB2L Keyboard Replacement: 步骤 3 中的图像 1,3 HP Chromebook CB2L Keyboard Replacement: 步骤 3 中的图像 2,3 HP Chromebook CB2L Keyboard Replacement: 步骤 3 中的图像 3,3
    • Starting in the top right-hand corner of the exposed metal piece, use the blue plastic opening tool to remove the back panel.
  4. HP Chromebook CB2L Keyboard Replacement: 步骤 4 中的图像 1,2 HP Chromebook CB2L Keyboard Replacement: 步骤 4 中的图像 2,2
    • Remove twenty 3.42mm screws with the Phillips #1 screwdriver.
  5. HP Chromebook CB2L Keyboard Replacement: 步骤 5 中的图像 1,2 HP Chromebook CB2L Keyboard Replacement: 步骤 5 中的图像 2,2
    • Remove the black and white antennae wires, the white ribbon cables, the large black connecter, and the speaker cable from the motherboard.
    • Grabbing the boards by the edges, remove the motherboard and audio/USB board.
  6. HP Chromebook CB2L Keyboard Replacement: 步骤 6 中的图像 1,3 HP Chromebook CB2L Keyboard Replacement: 步骤 6 中的图像 2,3 HP Chromebook CB2L Keyboard Replacement: 步骤 6 中的图像 3,3
    • Remove the red and blue antennae wires from the SIM card board.
    • Remove the SIM card tray.
    • Flip the board over and use the plastic opening tool to remove the ribbon cable, then remove the board.
  7. HP Chromebook CB2L Keyboard Replacement: 步骤 7 中的图像 1,2 HP Chromebook CB2L Keyboard Replacement: 步骤 7 中的图像 2,2
    • Remove the speakers and battery.
  8. HP Chromebook CB2L Keyboard Replacement: 步骤 8 中的图像 1,2 HP Chromebook CB2L Keyboard Replacement: 步骤 8 中的图像 2,2
    • Remove eighteen 2.5mm screws using the Phillips #1 screwdriver.
    • Flip the Chromebook so the top is on the table and the push out the keyboard from the back.
结论
Nathan Petrie
于10/31/18注册
277 声望
创作了2篇指南
团队
IUPUI, Team S1-G4, Harley Fall 2018 IUPUI, Team S1-G4, Harley Fall 2018 的会员
IUPUI-HARLEY-F18S1G4
3 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 181
