跳转到主内容
加入维修社区 - 创建账户
HP Chromebook CB2L Battery Replacement
你所需要的
    1. HP Chromebook CB2L Battery Replacement, Battery: 步骤 1 中的图像 1,2 HP Chromebook CB2L Battery Replacement, Battery: 步骤 1 中的图像 2,2
      • First flip your HP Chromebook CB2L over such that the bottom is facing upwards.
      • Next, using the plastic opening tool remove the blue panel.
      询问修复机器人
      添加评论
    2. HP Chromebook CB2L Battery Replacement: 步骤 2 中的图像 1,3 HP Chromebook CB2L Battery Replacement: 步骤 2 中的图像 2,3 HP Chromebook CB2L Battery Replacement: 步骤 2 中的图像 3,3
      • Using the Phillips #1 screwdriver, remove the six 1.2mm screws.
      • Gently pry off the white back panel using the plastic opening tool.
      询问修复机器人
      添加评论
    3. HP Chromebook CB2L Battery Replacement: 步骤 3 中的图像 1,1
      • Disconnect the battery input to the motherboard using the plastic opening tool
      询问修复机器人
      添加评论
    4. HP Chromebook CB2L Battery Replacement: 步骤 4 中的图像 1,1
      • Unscrew the four 1.2mm screws using the Phillips #1 screwdriver.
      询问修复机器人
      添加评论
    5. HP Chromebook CB2L Battery Replacement: 步骤 5 中的图像 1,1
      • Using the plastic opening tool remove the battery from the Chromebook.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
团队
USF Tampa, Team S2-G6, Lacy Spring 2017 USF Tampa, Team S2-G6, Lacy Spring 2017 的会员
USFT-LACY-S17S2G6
3 名成员
创作了36篇指南
2指南评论
the step about gently prying the underside of the laptop off made me snap off two screws under the thin blue rubber strip ! i see the holes they went in in the pictures in this guide. i understand that strip was glued on and it doesn't seem necessary to put those back (since i can't unglue the strip to put those screws back in) but.. yeah. it was unexpected and i thought i'd done something wrong.
katie - 回复 分享
Dont forget there are two screws underneath the small blue strip.
Roderick Wells - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 35
总计 1,818
