跳转到主内容
HP Chromebook 15 CB3-531-C4A5 Battery Replacement
你所需要的
  1. HP Chromebook 15 CB3-531-C4A5 Battery Replacement, Case: 步骤 1 中的图像 1,2 HP Chromebook 15 CB3-531-C4A5 Battery Replacement, Case: 步骤 1 中的图像 2,2
    • Remove the 18 Phillips screws using a screwdriver with a PH0 bit.
  2. HP Chromebook 15 CB3-531-C4A5 Battery Replacement: 步骤 2 中的图像 1,2 HP Chromebook 15 CB3-531-C4A5 Battery Replacement: 步骤 2 中的图像 2,2
    • Using a spudger, gently pry open the back from the top.
  3. HP Chromebook 15 CB3-531-C4A5 Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • Once it is opened up, locate the battery and the cable that is attached to it.
  4. HP Chromebook 15 CB3-531-C4A5 Battery Replacement: 步骤 4 中的图像 1,2 HP Chromebook 15 CB3-531-C4A5 Battery Replacement: 步骤 4 中的图像 2,2
    • Next, unscrew the battery pack. The one screw should be located on the far right of it. This will ensure that the battery comes out easily and affectively.
  5. HP Chromebook 15 CB3-531-C4A5 Battery Replacement: 步骤 5 中的图像 1,1
    • Take the battery out easily for replacement.
结论
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 2,101
