跳转到主内容
HP Chromebook 14-x013dx Speakers Replacement
你所需要的
  1. HP Chromebook 14-x013dx Speakers Replacement, Keyboard, Touchpad: 步骤 1 中的图像 1,2 HP Chromebook 14-x013dx Speakers Replacement, Keyboard, Touchpad: 步骤 1 中的图像 2,2
    • Using the plastic spudger, gently lift the 5 rubber pads away from their seating.
  2. HP Chromebook 14-x013dx Speakers Replacement: 步骤 2 中的图像 1,1
    • Remove the five 6mm screws located under the removed pads using Phillips #00 screwdriver.
  3. HP Chromebook 14-x013dx Speakers Replacement: 步骤 3 中的图像 1,2 HP Chromebook 14-x013dx Speakers Replacement: 步骤 3 中的图像 2,2
    • With the Phillips #00 screwdriver, remove the remaining eight 6mm screws. You will now have thirteen 6mm screws removed from the case.
  4. HP Chromebook 14-x013dx Speakers Replacement: 步骤 4 中的图像 1,2 HP Chromebook 14-x013dx Speakers Replacement: 步骤 4 中的图像 2,2
    • To continue removing the back cover, turn the laptop over as displayed.
    • Use the plastic spudger to gently pry around the base of the laptop from the back cover. Continue prying around the entire base of the laptop.
  5. HP Chromebook 14-x013dx Speakers Replacement: 步骤 5 中的图像 1,3 HP Chromebook 14-x013dx Speakers Replacement: 步骤 5 中的图像 2,3 HP Chromebook 14-x013dx Speakers Replacement: 步骤 5 中的图像 3,3
    • Gently lift the silver base of the laptop from the bottom, but do not remove it.
    • To remove the ribbon cables, lift the latch holding the ribbon cables in place and then pull them free.
    • Remove the keyboard panel from the laptop.
  6. HP Chromebook 14-x013dx Speakers Replacement, Battery: 步骤 6 中的图像 1,2 HP Chromebook 14-x013dx Speakers Replacement, Battery: 步骤 6 中的图像 2,2
    • Remove the eight 4mm screws holding the battery in place using the Phillips #00 screwdriver.
  7. HP Chromebook 14-x013dx Speakers Replacement: 步骤 7 中的图像 1,2 HP Chromebook 14-x013dx Speakers Replacement: 步骤 7 中的图像 2,2
    • Remove the ribbon cable that runs over the battery by lifting up the plastic latches and pulling the cable away.
  8. HP Chromebook 14-x013dx Speakers Replacement: 步骤 8 中的图像 1,2 HP Chromebook 14-x013dx Speakers Replacement: 步骤 8 中的图像 2,2
    • Unhook the battery's power connector from the motherboard.
  9. HP Chromebook 14-x013dx Speakers Replacement: 步骤 9 中的图像 1,1
    • Lift the battery out of the laptop case.
  10. HP Chromebook 14-x013dx Speakers Replacement, Speakers: 步骤 10 中的图像 1,2 HP Chromebook 14-x013dx Speakers Replacement, Speakers: 步骤 10 中的图像 2,2
    • Unplug Speaker from motherboard.
  11. HP Chromebook 14-x013dx Speakers Replacement: 步骤 11 中的图像 1,2 HP Chromebook 14-x013dx Speakers Replacement: 步骤 11 中的图像 2,2
    • Pull the left and right speaker out carefully.
    • The corners of the the speakers will be held in place by tape, and may require a bit of force.
  12. HP Chromebook 14-x013dx Speakers Replacement: 步骤 12 中的图像 1,2 HP Chromebook 14-x013dx Speakers Replacement: 步骤 12 中的图像 2,2
    • Remove the black tape holding the wire to the laptop casing.
    • Remove the wires from the three hooks on the case.
结论
另外一个人完成了本指南。
NHerbert
于09/28/17注册
602 声望
创作了5篇指南
团队
USF Tampa, Team S3-G6, Nance Fall 2017 USF Tampa, Team S3-G6, Nance Fall 2017 的会员
USFT-NANCE-F17S3G6
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 259
