跳转到主内容
HP Chromebook 14-x013dx Screen Replacement
你所需要的
  1. HP Chromebook 14-x013dx Screen Replacement, Screen: 步骤 1 中的图像 1,3 HP Chromebook 14-x013dx Screen Replacement, Screen: 步骤 1 中的图像 2,3 HP Chromebook 14-x013dx Screen Replacement, Screen: 步骤 1 中的图像 3,3
    • Remove lower left and right nylon flaps on the screen to remove the screws located underneath them.
    • The nylon strips on the side may be difficult to remove, as they are held on with adhesive. A spudger can be used to help remove these strips before removing with fingers.
    • Remove the two 2mm screws holding the bezel to the laptop case.
  2. HP Chromebook 14-x013dx Screen Replacement: 步骤 2 中的图像 1,2 HP Chromebook 14-x013dx Screen Replacement: 步骤 2 中的图像 2,2
    • Gently pry around the edges of the display using a spudger to remove the bezel that borders the screen.
  3. HP Chromebook 14-x013dx Screen Replacement: 步骤 3 中的图像 1,2 HP Chromebook 14-x013dx Screen Replacement: 步骤 3 中的图像 2,2
    • Remove glued plastic at the bottom of the cover.
  4. HP Chromebook 14-x013dx Screen Replacement: 步骤 4 中的图像 1,1
    • Once glue is separated, pop out the front cover by pulling upwards on the hinge.
  5. HP Chromebook 14-x013dx Screen Replacement: 步骤 5 中的图像 1,2 HP Chromebook 14-x013dx Screen Replacement: 步骤 5 中的图像 2,2
    • Once the bezel has been removed, remove the four 5mm screws at the corners of the screen using a PH00 screwdriver.
  6. HP Chromebook 14-x013dx Screen Replacement: 步骤 6 中的图像 1,3 HP Chromebook 14-x013dx Screen Replacement: 步骤 6 中的图像 2,3 HP Chromebook 14-x013dx Screen Replacement: 步骤 6 中的图像 3,3
    • Before completely removing the screen, detach the connected located at the bottom of the screen.
    • The connection to be removed should have a barcode marking.
结论
3等其他人完成本指南。
NHerbert
于09/28/17注册
602 声望
创作了5篇指南
团队
USF Tampa, Team S3-G6, Nance Fall 2017 USF Tampa, Team S3-G6, Nance Fall 2017 的会员
USFT-NANCE-F17S3G6
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 1,794
