跳转到主内容
HP Chromebook 14-x013dx I/O Board Replacement
你所需要的
  1. HP Chromebook 14-x013dx I/O Board Replacement, Keyboard, Touchpad: 步骤 1 中的图像 1,2 HP Chromebook 14-x013dx I/O Board Replacement, Keyboard, Touchpad: 步骤 1 中的图像 2,2
    • Using the plastic spudger, gently lift the 5 rubber pads away from their seating.
  2. HP Chromebook 14-x013dx I/O Board Replacement: 步骤 2 中的图像 1,1
    • Remove the five 6mm screws located under the removed pads using Phillips #00 screwdriver.
  3. HP Chromebook 14-x013dx I/O Board Replacement: 步骤 3 中的图像 1,2 HP Chromebook 14-x013dx I/O Board Replacement: 步骤 3 中的图像 2,2
    • With the Phillips #00 screwdriver, remove the remaining eight 6mm screws. You will now have thirteen 6mm screws removed from the case.
  4. HP Chromebook 14-x013dx I/O Board Replacement: 步骤 4 中的图像 1,2 HP Chromebook 14-x013dx I/O Board Replacement: 步骤 4 中的图像 2,2
    • To continue removing the back cover, turn the laptop over as displayed.
    • Use the plastic spudger to gently pry around the base of the laptop from the back cover. Continue prying around the entire base of the laptop.
  5. HP Chromebook 14-x013dx I/O Board Replacement: 步骤 5 中的图像 1,3 HP Chromebook 14-x013dx I/O Board Replacement: 步骤 5 中的图像 2,3 HP Chromebook 14-x013dx I/O Board Replacement: 步骤 5 中的图像 3,3
    • Gently lift the silver base of the laptop from the bottom, but do not remove it.
    • To remove the ribbon cables, lift the latch holding the ribbon cables in place and then pull them free.
    • Remove the keyboard panel from the laptop.
  6. HP Chromebook 14-x013dx I/O Board Replacement, I/O Board: 步骤 6 中的图像 1,2 HP Chromebook 14-x013dx I/O Board Replacement, I/O Board: 步骤 6 中的图像 2,2
    • Unhook the ribbon connecting the I/O board and the battery.
    • To remove the ribbon, lift the latch holding the ribbons in place and then pull them free.
  7. HP Chromebook 14-x013dx I/O Board Replacement: 步骤 7 中的图像 1,2 HP Chromebook 14-x013dx I/O Board Replacement: 步骤 7 中的图像 2,2
    • Remove two 2mm screws from the I/O board using the Phillips PH00 screwdriver.
  8. HP Chromebook 14-x013dx I/O Board Replacement: 步骤 8 中的图像 1,1
    • Lift the I/O board out of the laptop case.
结论
2等其他人完成本指南。
NHerbert
于09/28/17注册
602 声望
创作了5篇指南
团队
USF Tampa, Team S3-G6, Nance Fall 2017 USF Tampa, Team S3-G6, Nance Fall 2017 的会员
USFT-NANCE-F17S3G6
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 13
总计 474
