简介
This guide walks through how to remove a malfunctioning camera in an HP Chromebook 14-x013dx. This replacement requires disabling the keyboard from the laptop and removing the lid, and the total repair time should take about 30 minutes.
你所需要的
Using the plastic spudger, gently lift the 5 rubber pads away from their seating.
Disconnect the black and white wires connected to the Wi-Fi module.
Remove the wire from the casing.
另外一个人完成了本指南。
一条评论
Thank you, very helpful. You could also just start at Step 10 without removing the display
