跳转到主内容
HP Chromebook 14-x013dx Camera Replacement
你所需要的
  1. HP Chromebook 14-x013dx Camera Replacement, Keyboard, Touchpad: 步骤 1 中的图像 1,2 HP Chromebook 14-x013dx Camera Replacement, Keyboard, Touchpad: 步骤 1 中的图像 2,2
    • Using the plastic spudger, gently lift the 5 rubber pads away from their seating.
  2. HP Chromebook 14-x013dx Camera Replacement: 步骤 2 中的图像 1,1
    • Remove the five 6mm screws located under the removed pads using Phillips #00 screwdriver.
  3. HP Chromebook 14-x013dx Camera Replacement: 步骤 3 中的图像 1,2 HP Chromebook 14-x013dx Camera Replacement: 步骤 3 中的图像 2,2
    • With the Phillips #00 screwdriver, remove the remaining eight 6mm screws. You will now have thirteen 6mm screws removed from the case.
  4. HP Chromebook 14-x013dx Camera Replacement: 步骤 4 中的图像 1,2 HP Chromebook 14-x013dx Camera Replacement: 步骤 4 中的图像 2,2
    • To continue removing the back cover, turn the laptop over as displayed.
    • Use the plastic spudger to gently pry around the base of the laptop from the back cover. Continue prying around the entire base of the laptop.
  5. HP Chromebook 14-x013dx Camera Replacement: 步骤 5 中的图像 1,3 HP Chromebook 14-x013dx Camera Replacement: 步骤 5 中的图像 2,3 HP Chromebook 14-x013dx Camera Replacement: 步骤 5 中的图像 3,3
    • Gently lift the silver base of the laptop from the bottom, but do not remove it.
    • To remove the ribbon cables, lift the latch holding the ribbon cables in place and then pull them free.
    • Remove the keyboard panel from the laptop.
  6. HP Chromebook 14-x013dx Camera Replacement, Camera: 步骤 6 中的图像 1,2 HP Chromebook 14-x013dx Camera Replacement, Camera: 步骤 6 中的图像 2,2
    • Disconnect the black and white wires connected to the Wi-Fi module.
    • Remove the wire from the casing.
  7. HP Chromebook 14-x013dx Camera Replacement: 步骤 7 中的图像 1,1
    • Pull the ribbon cable out of socket.
  8. HP Chromebook 14-x013dx Camera Replacement: 步骤 8 中的图像 1,3 HP Chromebook 14-x013dx Camera Replacement: 步骤 8 中的图像 2,3 HP Chromebook 14-x013dx Camera Replacement: 步骤 8 中的图像 3,3
    • Use a Phillips #00 screwdriver to remove the two 6mm screws located at the upper left and right corners.
  9. HP Chromebook 14-x013dx Camera Replacement: 步骤 9 中的图像 1,2 HP Chromebook 14-x013dx Camera Replacement: 步骤 9 中的图像 2,2
    • Remove the lid out of the laptop.
    • It is helpful to rotate the lid to a 90-degree angle.
  10. HP Chromebook 14-x013dx Camera Replacement: 步骤 10 中的图像 1,1
    • Using the plastic opening tool, pry the left and right side of the top of the lid.
    • It is not necessary to remove the entire frame, only pry the top to expose the camera.
  11. HP Chromebook 14-x013dx Camera Replacement: 步骤 11 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Using tweezers, gently remove the connection hold the camera in place.
  12. HP Chromebook 14-x013dx Camera Replacement: 步骤 12 中的图像 1,2 HP Chromebook 14-x013dx Camera Replacement: 步骤 12 中的图像 2,2
    • Gently pry the camera mount out of the lid.
    • Lift the camera mount out of the lid.
结论
另外一个人完成了本指南。
Eile Woeltje
于11/06/19注册
304 声望
创作了2篇指南
团队
IUPUI, Team S1-G3, Stella Fall 2019 IUPUI, Team S1-G3, Stella Fall 2019 的会员
IUPUI-STELLA-F19S1G3
3 名成员
创作了2篇指南
一条评论
Thank you, very helpful. You could also just start at Step 10 without removing the display
Douglas Walker - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 776
