跳转到主内容
HP Chromebook 14-x010wm Battery Replacement
你所需要的
  1. HP Chromebook 14-x010wm Battery Replacement, Battery: 步骤 1 中的图像 1,3 HP Chromebook 14-x010wm Battery Replacement, Battery: 步骤 1 中的图像 2,3 HP Chromebook 14-x010wm Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Remove the thirteen 5.7mm screws from the back of the laptop using a Phillips #00 screwdriver.
    • Remove rubber covers to reveal concealed screws, as needed.
  2. HP Chromebook 14-x010wm Battery Replacement: 步骤 2 中的图像 1,3 HP Chromebook 14-x010wm Battery Replacement: 步骤 2 中的图像 2,3 HP Chromebook 14-x010wm Battery Replacement: 步骤 2 中的图像 3,3
    • Flip the laptop over carefully and open the cover.
    • Use a plastic opening tool to pry open the front edge and along the sides of the keyboard cover to separate it from the computer’s base.
    • Lift the keyboard cover from the computer’s base carefully.
  3. HP Chromebook 14-x010wm Battery Replacement: 步骤 3 中的图像 1,3 HP Chromebook 14-x010wm Battery Replacement: 步骤 3 中的图像 2,3 HP Chromebook 14-x010wm Battery Replacement: 步骤 3 中的图像 3,3
    • Lifting the keyboard cover too much may damage the internal cables of the laptop.
    • Lift the black plastic flap, using a plastic opening tool, of the zero insertion force (ZIF) connector that holds the keyboard cable in place.
    • Disconnect the keyboard cable by slowly pulling it from the system board.
    • Lift the black plastic flap that holds the battery cable in place using a plastic opening tool.
    • Remove the battery cable by slowly pulling the plastic connector towards you.
    • Remove carefully and set aside keyboard panel.
  4. HP Chromebook 14-x010wm Battery Replacement: 步骤 4 中的图像 1,2 HP Chromebook 14-x010wm Battery Replacement: 步骤 4 中的图像 2,2
    • Flip the plastic flap holding the battery cable using a plastic opening tool.
    • Disconnect the battery cable by carefully pulling it from the system board.
  5. HP Chromebook 14-x010wm Battery Replacement: 步骤 5 中的图像 1,3 HP Chromebook 14-x010wm Battery Replacement: 步骤 5 中的图像 2,3 HP Chromebook 14-x010wm Battery Replacement: 步骤 5 中的图像 3,3
    • Remove the seven M2xL3.0 screws from around the battery using a Phillips #00 screwdriver.
  6. HP Chromebook 14-x010wm Battery Replacement: 步骤 6 中的图像 1,2 HP Chromebook 14-x010wm Battery Replacement: 步骤 6 中的图像 2,2
    • Peel the wire band off of the battery carefully.
    • Remove the battery by lifting slightly, then slowly pull it towards you.
结论
Follow these instructions in reverse order to reassemble your device.
Tyler Stover
于04/02/19注册
137 声望
撰写一个指南
团队
IUPUI, Team S3-G3, Harley Spring 2019 IUPUI, Team S3-G3, Harley Spring 2019 的会员
IUPUI-HARLEY-S19S3G3
3 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 375
