跳转到主内容
HP Chromebook 14-ca061dx Battery Replacement
你所需要的
  1. HP Chromebook 14-ca061dx Battery Replacement, Keyboard: 步骤 1 中的图像 1,3 HP Chromebook 14-ca061dx Battery Replacement, Keyboard: 步骤 1 中的图像 2,3 HP Chromebook 14-ca061dx Battery Replacement, Keyboard: 步骤 1 中的图像 3,3
    在这个步骤中使用的工具:
    $3.99
    购买
    • Flip the Chromebook to the underside with the hinge at the top.
    • Remove the seven, small rubber stoppers using angled tweezers.
  2. HP Chromebook 14-ca061dx Battery Replacement: 步骤 2 中的图像 1,3 HP Chromebook 14-ca061dx Battery Replacement: 步骤 2 中的图像 2,3 HP Chromebook 14-ca061dx Battery Replacement: 步骤 2 中的图像 3,3
    • Remove the two bigger rubber stoppers using a metal spudger.
  3. HP Chromebook 14-ca061dx Battery Replacement: 步骤 3 中的图像 1,2 HP Chromebook 14-ca061dx Battery Replacement: 步骤 3 中的图像 2,2
    • Remove the seven 6mm Phillips #00 screws found underneath the stoppers.
  4. HP Chromebook 14-ca061dx Battery Replacement: 步骤 4 中的图像 1,2 HP Chromebook 14-ca061dx Battery Replacement: 步骤 4 中的图像 2,2
    • Remove the two 9mm Phillips #1 screws.
  5. HP Chromebook 14-ca061dx Battery Replacement: 步骤 5 中的图像 1,3 HP Chromebook 14-ca061dx Battery Replacement: 步骤 5 中的图像 2,3 HP Chromebook 14-ca061dx Battery Replacement: 步骤 5 中的图像 3,3
    • Flip the Chromebook over and open the cover.
    • Insert the iFixit opening tool into the edge of the keyboard, near the mouse pad.
    • By lifting the tool at an angle, work the tool around the entire perimeter of the keyboard.
    • You will hear a popping noise when you disconnect the keyboard.
  6. HP Chromebook 14-ca061dx Battery Replacement: 步骤 6 中的图像 1,3 HP Chromebook 14-ca061dx Battery Replacement: 步骤 6 中的图像 2,3 HP Chromebook 14-ca061dx Battery Replacement: 步骤 6 中的图像 3,3
    • Lift the keyboard from the mouse pad.
    • Lift the keyboard carefully, because there are cables connecting the keyboard to the base and they may break.
    • Use your finger or the spudger tool to flip up the black locking flap.
    • Grab the black cable and pull away from the motherboard.
    • Carefully lift the black piece up, because it is fragile and can break easily.
  7. HP Chromebook 14-ca061dx Battery Replacement: 步骤 7 中的图像 1,3 HP Chromebook 14-ca061dx Battery Replacement: 步骤 7 中的图像 2,3 HP Chromebook 14-ca061dx Battery Replacement: 步骤 7 中的图像 3,3
    • Flip up the white locking flap with your finger or spudger tool.
    • Remove the white cable from the motherboard.
    • Carefully lift the white piece up, because it is fragile and can break easily.
  8. HP Chromebook 14-ca061dx Battery Replacement: 步骤 8 中的图像 1,1
    • Lift the rest of the keyboard up from the base of the Chromebook.
  9. HP Chromebook 14-ca061dx Battery Replacement, Battery: 步骤 9 中的图像 1,2 HP Chromebook 14-ca061dx Battery Replacement, Battery: 步骤 9 中的图像 2,2
    • Remove the four 4mm Phillips #0 screws from the battery.
  10. HP Chromebook 14-ca061dx Battery Replacement: 步骤 10 中的图像 1,3 HP Chromebook 14-ca061dx Battery Replacement: 步骤 10 中的图像 2,3 HP Chromebook 14-ca061dx Battery Replacement: 步骤 10 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Peel back the black electrical tape from the motherboard using a pair of tweezers.
    • Using your finger, pull the white plastic piece toward you.
  11. HP Chromebook 14-ca061dx Battery Replacement: 步骤 11 中的图像 1,1
    • Remove the battery from the base of the Chromebook.
结论
4等其他人完成本指南。
Jean Arevalo
于10/31/19注册
778 声望
创作了6篇指南
团队
UMass Dartmouth, Team S2-G5, Barthe Fall 2019 UMass Dartmouth, Team S2-G5, Barthe Fall 2019 的会员
UMASSD-BARTHE-F19S2G5
3 名成员
创作了6篇指南
一条评论
Great job documenting the procedure.
Dennis Gregory - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 26
总计 1,715
