跳转到主内容
HP Chromebook 14-ak013dx Touchpad Replacement
你所需要的
  1. HP Chromebook 14-ak013dx Touchpad Replacement, Disassemble the Body: 步骤 1 中的图像 1,3 HP Chromebook 14-ak013dx Touchpad Replacement, Disassemble the Body: 步骤 1 中的图像 2,3 HP Chromebook 14-ak013dx Touchpad Replacement, Disassemble the Body: 步骤 1 中的图像 3,3
    • With the laptop upside down, remove the 13 screws with a P0 screwdriver (2 screws are located under the rubber footpads)
    • Open the screen, accessing the keyboard; gently pry the keyboard off the body careful not to pull out the ribbons
  2. HP Chromebook 14-ak013dx Touchpad Replacement, Disconnecting the Keyboard from the Body: 步骤 2 中的图像 1,3 HP Chromebook 14-ak013dx Touchpad Replacement, Disconnecting the Keyboard from the Body: 步骤 2 中的图像 2,3 HP Chromebook 14-ak013dx Touchpad Replacement, Disconnecting the Keyboard from the Body: 步骤 2 中的图像 3,3
    • Gently lift up the keyboard from the main body, careful not to pull out the ribbons
    • The black bars holding the ribbons in place will flip up with light pressure, releasing the ribbons
  3. HP Chromebook 14-ak013dx Touchpad Replacement, Disconnecting the Touchpad from the Keyboard: 步骤 3 中的图像 1,3 HP Chromebook 14-ak013dx Touchpad Replacement, Disconnecting the Touchpad from the Keyboard: 步骤 3 中的图像 2,3 HP Chromebook 14-ak013dx Touchpad Replacement, Disconnecting the Touchpad from the Keyboard: 步骤 3 中的图像 3,3
    • Separate the keyboard from the main body of the laptop
    • Using a P00 Screwdriver, remove the two screws holding the touchpad in place
    • Use light pressure to flip up the black bar holding the ribbon in place
  4. HP Chromebook 14-ak013dx Touchpad Replacement, Removing the Touchpad: 步骤 4 中的图像 1,2 HP Chromebook 14-ak013dx Touchpad Replacement, Removing the Touchpad: 步骤 4 中的图像 2,2
    • Use a tool to push down on the knob highlighted, the touchpad will fall out of the front of the keyboard
    • If not immediately replacing the touchpad, safely secure the old keyboard
结论
To reassemble your device, follow these instructions in reverse order. Ribbon guards should fall back into place securely. Keyboard should 'snap' back into place before the 13 screws.
另外一个人完成了本指南。
团队
dwsad dwsad 的会员
Community
1 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 106
